Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Why the HP diff in Harley vs Lightning
Old Jul 24, 2004 | 03:56 PM
jarepackard's Avatar
jarepackard
Can anyone tell me why the stock Lightning makes 40 more hp than the Harley? Is the boost and charger the same on both trucks and perhaps there are other differences?
Old Jul 24, 2004 | 11:46 PM
FTE Ken's Avatar
FTE Ken
The Harley has a larger upper pulley causing less boost.
Old Jul 26, 2004 | 02:44 PM
jarepackard
With that in mind then all I would have to do is change pulleys to increase boost from 6 to 8 which should put it on par with a Lightning engine.
Old Aug 1, 2004 | 11:51 PM
BVFD1983's Avatar
BVFD1983
The Harley engine is basically a 5.4 with a blower on top. The Lightning engine has many internal changes.
Old Aug 2, 2004 | 07:08 AM
msmarcus's Avatar
msmarcus
Both engines are exactly the same with the exception of the upper pulley and a richer, more utilitary tune in the computer.
Old Aug 2, 2004 | 12:25 PM
02harley's Avatar
02harley
just downsized my upper pulley to a 4lb. big jump in hp and torque. the tuner i have is through Diablo and it has a "pulley tune" option to help adjust the air to fuel ratio's...but still im told it could/possibly detonate...but i have been told that it won't...
Old Aug 5, 2004 | 05:55 PM
Lightning Rod's Avatar
Lightning Rod
Pushing four extra pounds of boost w/o the proper tune is a recipe for disaster.
Get the truck up on a dyno and take an Air/Fuel reading. Anything higher than a 12.7 and you're in the risky zone.
Old Aug 6, 2004 | 09:34 AM
02harley's Avatar
02harley
just did yesterday...and its running smoothly. 366hp to rear wheels and 468lbs of Tq.
Old Aug 6, 2004 | 01:04 PM
Lightning Rod
What was your A/F reading?
Old Aug 9, 2004 | 03:53 PM
02harley's Avatar
02harley
They didnt probe it...
However, i do have a Diablo tuner which the manual say to program the "pulley tune" once the upper pulley is replaced with a smaller one...4-6lb. The guy said that my cat was popping a lot, which meant that it was running to rich...so he recommended to go back to the "performance tune" of the programmer...so i did.
Next week or so, im going to have the lower pulley changed out, and they are going to pull my computer and burn a specific chip for it and re-callibrate the A/F ratio's.
Old Aug 11, 2004 | 01:31 AM
2000 Harley's Avatar
2000 Harley
The HD"s have a different piston & ring configuration than the L. The block is exactly the same as with all the parts with the exception of the Damper pulley, SC pulley, & the factory programing. They are not far from the regular 5.4L as far as internal componets are concerned. (A slight difference in the rings & bore).
It should be OK, but like Lightning Rod said I would be cautious! If you change your SC pulley you have to upgrade your Damper pulley!! and the idle pulley as well.
Your programming has to be dead on
2000 Harley
wa-sleeper
Aug 13, 2016 07:57 PM
rockrig4x4
May 7, 2016 06:17 PM
Rooster403
1997 - 2003 F150
Jan 31, 2016 09:02 AM
Todd Wenke
Nov 20, 2015 08:08 PM
rockrig4x4
Nov 11, 2015 03:03 AM
