97 Explorer code P0446
Old Apr 2, 2002 | 06:36 PM
Sid06's Avatar
Sid06
Post 97 Explorer code P0446
mil light on and code P0446 cannister vent mafunction any ideas.
Old Apr 3, 2002 | 12:17 AM
PAUL_2's Avatar
PAUL_2
Did you refuel while the engine was running or forget to replace the gas cap & start the engine ?
Old Apr 3, 2002 | 09:25 AM
Sid06's Avatar
Sid06
No it started out as an intermitent problem but now it stays on all the time. I can clear the code and it will come back on somewhere around 150-200 miles. I searched the nhtsa site for TSB and found 1 #BC0312970501. The last time I had it at the dealer the lite went out before I got there and they said there were no hard codes and I haven't had a chance to get it back yet.
Old Apr 3, 2002 | 10:55 AM
PAUL_2's Avatar
PAUL_2
Ok , Which engine does your Explorer have , Etc ?
Old Apr 3, 2002 | 11:10 AM
Sid06's Avatar
Sid06
5.0 Liter Auto AWD
Old Apr 3, 2002 | 11:29 PM
PAUL_2's Avatar
PAUL_2
It may be the gas cap is leaking , faulty . Also check the fuel filler pipe , it may be venting some pressure due to a clamp being loose etc . Check all the Evap Emission hoses as well .
Old Apr 8, 2002 | 11:55 AM
Sid06's Avatar
Sid06
I inspected the gas cap and all the emmision lines from front to back.
I decided the valve on the vapor canister was stuck open the vapor canister is located on the frame in the rear mounted above the spare tire and gets alot of dirt and grime from the road thrown up on it. I have driven it several miles and every thing seems to be working no codes yet. Thanks for your help.
Phillip Fell
Old Apr 8, 2002 | 12:57 PM
CobraXP's Avatar
CobraXP
Villengineer
Sep 30, 2014 03:53 PM
joshco
2004 - 2008 F150
Jan 15, 2014 08:23 PM
Diesel_Brad
1983 - 2012 Ranger & B-Series
37
Aug 2, 2013 04:18 AM
rangerguy52
Jan 29, 2006 12:18 PM
jp756
Jun 10, 2004 07:22 AM
