Code P0446
Old Jun 8, 2004 | 10:27 AM
jp756's Avatar
jp756
Code P0446
1996 5.0L Explorer gives error code P0446 with text: evap purge/vent solenoid malfunction. Any suggestions?
Old Jun 8, 2004 | 10:38 AM
thelonerangerxlt's Avatar
thelonerangerxlt
Jp, first make sure the gas cap is sealing correctly. If it's OK, then the purge solenoid is probably the culprit. It's located above the spare tire, and is easy to change.
Old Jun 8, 2004 | 05:11 PM
Fr8hauler's Avatar
Fr8hauler
I had same code. Solenoid cost about $35.00 from dealer and was very easy to change. You have to drop spare and then remove four bolts to drop the plate the solenoid is attached to. Good luck.
Old Jun 10, 2004 | 07:22 AM
97EXP's Avatar
97EXP
I currently have the same problem/code. Interested in how things turn out for you. I plan on fixing my truck next week.
Villengineer
Sep 30, 2014 03:53 PM
Diesel_Brad
1983 - 2012 Ranger & B-Series
37
Aug 2, 2013 04:18 AM
rangerguy52
Jan 29, 2006 12:18 PM
rigo
Dec 28, 1999 06:59 PM
