Bronco II Ford Bronco II
Steering columns interchangable?
Old Jul 22, 2004 | 04:51 PM
ShawnZ's Avatar
ShawnZ
Unhappy Steering columns interchangable?
I have an '85 Bronco II and I am going to be doing some stuff to it. One thing I want to do to it is change the steering column to one I saw for an old bronco (67?) and dont know how hard that would be. Could anyone help me with this?
Old Jul 22, 2004 | 07:48 PM
heatmon's Avatar
heatmon
Question Steering Column
ShawnZ,
Aren't newer steering columns "collapsable" in the event of a front end collision?
Aren't older steering columns deadly in some front end collisions?
Will the benefits outweigh the bad possibilities?
I'm not sure when detroit/dearborn made the switch but it's something to consider. Just my 2 cents worth.
Old Jul 22, 2004 | 09:30 PM
fellro86's Avatar
fellro86
next problem is the lack of keyswitch.
Old Jul 23, 2004 | 08:02 PM
ShawnZ's Avatar
ShawnZ
What is a keyswitch?
I'll check that out Heatmon
Old Jul 23, 2004 | 11:47 PM
fellro86's Avatar
fellro86
the place you put the key, on the older units it was in the dash, on the newer it is on the column. You also don't have an ignition switch on the column as well.
Old Jul 24, 2004 | 09:05 AM
ShawnZ's Avatar
ShawnZ
oohhhh... I see. Well, ok, say I found a different column that I liked with the ignition switch on the column, what would be stopping me from putting it in? Or would it depend on what the other steering column was made for. I am not talking about upgrading to CC or anything like that either.
Old Jul 24, 2004 | 10:17 AM
fellro86's Avatar
fellro86
biggest troubles are the firewall plate and the column munts, as well as the hookup to the steering box. Rangers and Bronc II's trade back and forth, so that's your safest and easiest way to go.
rwrogers
Jan 29, 2014 06:58 PM
Corkwheats
WTB - Parts & other
Jan 4, 2013 11:14 PM
52' fordnut
Dec 10, 2012 07:51 PM
Zellian
Bronco II
Oct 25, 2009 01:27 PM
RippedBronco
1978 - 1996 Big Bronco
Feb 18, 2004 09:43 PM
