were can i get power windows for a 79 ford f150 i really cant spend alot. And about every month or 2 my battery keeps shorting out i hav no clue wat it is.
The only place I know of that makes a kit specifically for our trucks to convert to power windows is Electric Life (www.electric-life.com) I believe they're sold through JC Whitney but they'll run you in the $200 range if I remember right.
Oh, and for the battery, it could be any one of a million things but check this thread out, some great info on possible issues with power and ways to track down the drain: https://www.ford-trucks.com/forums/s...ad.php?t=44223
got my set ...dont remember how much they were but they were less than 200....ill have to post some pics of the install...i stuck the switches on the dash....looks pretty good and gives a nice custom feel to the truck...wasnt too bad...i went slow and it only took me a few hours to do all the install....good luck
good god, a guy leaves for a few months and you guys forget all the stuff he posted! LOL use the power windows from a mid 80's ford pickup. it is an all but bolt in swap. you have to drill a couple of new holes in door where the old regulator bolted in, you have to make a couple of spacers to mount the regulator flat, and you have to file the nylon roller flatter to fit in teh earlier groove but it is a piece of cake and i got power door locks out of the deal too! i used all the wiring as is which is great because it has those accordians in the door jambs. too easy to do and even easier to get parts for. hawkrod
