code 41 only when a/c is on: '92 460
Old Jul 21, 2004 | 11:58 PM
truckRN's Avatar
truckRN
Wink code 41 only when a/c is on: '92 460
I have a '92 f-350 460 7.5 L 167,000. She only sets code 41 (running lean) when the a/c is on. The egr and sensor are new. It was idling rough and sluggish so I replaced the idle air bypass and that fixed that problem. I did all the typical tune up stuff (plugs, wires, cap, rotor, fuel filter, air filters, pvc valve) replaced o2 sensor, checked for vac leaks, checked electrical connectors, batt. is new, and changed the alt. So, where to go from here besides the shop? I will check the ECT sensor and throttle position sensor.
It also seems my temp gauge on the dash is lower than usual and takes a while to come up.
Any advice is greatly appreciated if anyone is familiar with this problem. I don't have lots of time and since I'm not a mechanic it take me much longer to study these manuals and proceed accordingly. (Oh, the things a girl has to do!) But I like my truck and I try to keep her in good shape.
marbleman
1978 - 1996 Big Bronco
Jun 28, 2013 02:43 PM
Reed
Nov 22, 2010 10:20 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Jun 16, 2007 07:57 PM
CPU Slayer
Jul 27, 2003 02:06 PM
grousehunter
Apr 3, 2003 09:39 PM
