Brakes squeak??!!
Old Jul 21, 2004 | 10:39 PM
99xlt4.04x4's Avatar
99xlt4.04x4
Brakes squeak??!!
The rotors are really good, and the pads aren't bad. My problem is thebrakes squeak when im not even touching the brake pedal. IS there a spring or some sort of release mechanism that spreads the pads back apart. I have cleaned the brakes several times and it works for a few miles, then back to normal. I looked for a spring last time i cleaned them when i had the tire off, but i didnt have time to take the calipers apart.
Thanx in advance.
Old Jul 21, 2004 | 11:44 PM
g_k50's Avatar
g_k50
My understanding is that there is a piece of metal that causes the squeak when the pad is at it's wear limit. You might have your brakes checked by a mechanic to see if they need new pads.
Old Jul 22, 2004 | 02:48 PM
Ken00's Avatar
Ken00
The calipers ride on slide pins, make sure they are lubed good with brake grease.
Old Jul 22, 2004 | 03:45 PM
99xlt4.04x4
Im gonna go ahead and get new pads, and while they are off, clean and lube everything really well. Thanx for the replies.
Old Jul 22, 2004 | 03:53 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Good move on the new pads. Some aftermarket pads, being of whatever material, cause squeaks. Therefore, my suggestion would be to bite the bullet and see the dealer parts department (I think they are around $45). After all, the dealer's service department wouldn't want to waste time on rework, they want it right the first time.
ebbnflow
Jan 25, 2015 06:00 AM
F-750pickup
Oct 26, 2012 12:06 PM
xjcamaro89
2004 - 2008 F150
Aug 2, 2010 12:52 PM
naiku
May 23, 2006 12:20 PM
Kylenovak97
2004 - 2008 F150
Apr 11, 2005 02:25 PM
