Sponsored by: Real Truck
2005 250SD Height question
Old Jul 21, 2004 | 03:29 PM
fastnboat's Avatar
fastnboat
The "standard" dimensions for a 2005 CrewCab 4WD SB shows a vehicle height of 80.0".
Many of the parking garages I use have a max height of 6'8".
If I add 18" wheels, will that increase the vehicle height by 1" to 81"?
Old Jul 21, 2004 | 05:56 PM
1956MarkII's Avatar
1956MarkII
Assuming you use the same tires, that will add 1/2", because half of the extra inch will be ABOVE your axle. You can even lower the overall height by switching to lower-profile tires, even with 18" wheels.
Old Jul 21, 2004 | 08:28 PM
EKUgrad's Avatar
EKUgrad
80.3"
too close for comfort for me
Old Jul 21, 2004 | 08:53 PM
02superstroker's Avatar
02superstroker
as long as the tire diameter is the same, the wheel size isn't going to affect the height...
DO the 18" rims use bigger tires?
Old Jul 21, 2004 | 09:45 PM
logansdad's Avatar
logansdad
what about the 20's on the Harley's
Old Jul 21, 2004 | 10:39 PM
02superstroker
I repeat myself.
However, since a smaller diameter rim's tire will have a larger sidewall area which will allow for more flex in that area it could "sit" a bit lower than the same size tire on a larger rim since there is less sidewall. However is also greatly effected by air pressure, and whether the two are the same or not. All of this is talking about differences that are so small it really wouldn't change the height dramatically. So, to answer your question - don't worry about RIM/WHEEL size on vehicle height, worry about the TIRE DIAMETER.
Although if you are only running rims and no tires then yeah, the rim diameter is going to make a difference...
Old Jul 22, 2004 | 12:14 AM
Autobahn F-250 Lariat's Avatar
Here a few examples of the same brand(Nitto) tire and different size rims:
LT325/70 R16 121Q 16.5 33.86 13.03
LT325/60 R18 119S 15.6 32.99 12.83
LT325/60 R20 121R 15.6 35.12 12.91
LT325/50 R22 122R 15.6 34.84 12.95
Old Jul 22, 2004 | 04:53 AM
V10man's Avatar
V10man
Don't they come with 18" wheels now standard?
Old Jul 22, 2004 | 06:33 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
From what I have read 18" rims on all of them. made room for bigger brakes
Old Jul 22, 2004 | 10:40 AM
1956MarkII's Avatar
1956MarkII
17s standard on 250, 18s optional. 18s standard on SRW 350. DRW gets only 17s.
Old Jul 22, 2004 | 06:38 PM
V10man's Avatar
V10man
Well I'll be damed... Your right Jeff.(like I had any doubts) F250's get the 17" wheels and choice of 245x75R17 or 265x70R17 tires. I thought 18" wheels were accross the board. Do you have any pics of the 17" wheels yet Jeff?
That is great news for me really. There are many more options in 17" than 18" (least for now) Maxxis MT753 , MT754 Buckshot Mudder(nice) and others.
ol-blu
Nov 6, 2024 08:05 AM
Billdog103
1947 and Older Ford Trucks
May 31, 2007 04:26 PM
Birch
Aug 6, 2005 02:14 PM
threefiftyone
Jan 14, 2005 08:12 PM
truckfarmer
Apr 19, 2001 09:04 PM
