Radiator Drain Valve
Old Jul 21, 2004 | 11:51 AM
hailstreak's Avatar
hailstreak
Hi everyone,
I just purchased a 2000 Ford Ranger and I am going to flush the cooling system. Where is the radiator drain valve? On the bottom passenger side of the radiator, I see a plastic hex screw. Is this the drain valve, or not? I am a novice at auto maintenance/repair, and would appreciate any help.
Bud
Old Jul 21, 2004 | 01:33 PM
Vin 95's Avatar
Vin 95
Yeah,thats your drain valve.BE CAREFUL with it,it is plastic and will strip easily,so be sure you turn it the right way to loosen and don't over tighten it.I usually stick a small peice of hose on the end of it and drain it into a jug or pan so it does'nt run all over and make a mess.
Old Jul 21, 2004 | 10:42 PM
99xlt4.04x4's Avatar
99xlt4.04x4
Yeah, they snap off pretty easy. The hose thing sounds pretty cool. Next time ill have to do that instead of letting it run everywhere and try to get the pan under the biggest stream.
DMTR
Aerostar
31
Jan 31, 2014 06:31 PM
6litrefan
Aug 14, 2012 08:38 PM
va150
Mar 23, 2011 08:24 AM
Jmatthews
Mar 20, 2011 05:33 PM
JoeF150
Oct 30, 2002 01:15 AM
