Aerostar Ford Aerostar
Power steering pump replacement
Old Jul 20, 2004 | 09:17 PM
390fe's Avatar
390fe
The front bearing in my '91 Aerostar's 4.0l went south last night, taking the front seal as well. In order to replace the pump, I need to remove the ac compressor, then the bracket holding the pump, right? Take the pump and bracket out as a whole unit, remove the ps pulley from the pump, remove the pump from the bracket, and reverse to reinstall? I'm trying to avoid any unpleasant surprizes.
Old Jul 21, 2004 | 12:27 AM
Racerguy's Avatar
Racerguy
It's been ages since I've done one but I think you can remove the pulley and then the pump without removing the whole bracket.
Old Jul 21, 2004 | 06:02 AM
nightshifter's Avatar
nightshifter
you might find it easier to deal with the pulley while it's still mounted. I've gone through several of those boogers on my 94, until I finally replaced the rack & pinion at the same time. Make sure you get your lines back up and in place when your done, it's not fun to discover them dragging the ground later. Good luck.
Old Jul 21, 2004 | 03:52 PM
Muffinman's Avatar
Muffinman
And remember that hose is a High-Low Pressure in one unit.
Old Jul 22, 2004 | 11:29 AM
Berry's Avatar
Berry
The pump is like other ford power steering pumps and there is a neat little puller you can buy for small $$ that removes the pully before you take the pump off the bracket. The pulley has to come off the shaft to get it off the bracket.
I just did my mustang and the pump on the aerostar is the same set up.
There may be a difference in threads (sae vs. metric) on the newer pumps so make sure you get the one for your application.
Here is the url to a page that shows an example of what you need.
Item #1796 - ISN OTC 7185
http://www.autospecialtytools.com/cg...?doc=ford.dht&
I got one at pep boys and it cost a LOT less than what is shown here.
Old Jul 22, 2004 | 03:50 PM
GoneFishen's Avatar
GoneFishen
I'd also recommend installing an in-line filter on the return line, like a 3/8" magnefine. I wished I'd put one on mine BEFORE my pump sent metal shavings through the R&P. I have one on both my vehicles now.
John
Old Jul 22, 2004 | 03:55 PM
390fe's Avatar
390fe
It looks like I'll be able to get this thing done this weekend. Thanks for the information guys!
Redfridge
Feb 10, 2014 04:50 AM
xirxious
Aug 21, 2009 09:58 PM
nhouston
3.0L V6
Oct 29, 2008 01:36 PM
JimJ
1983 - 2012 Ranger & B-Series
Aug 29, 2003 01:13 PM
