460 Rough Idle?
Old Jul 19, 2004 | 05:28 AM
mpmccarthy's Avatar
mpmccarthy
460 Rough Idle?
I replaced the EGR valve along with some other stuff - more for PM than any other reason. Along the way I developed an exhaust leak that I couldn't find.
Turns out the pipe between the header and the EGR valve had cracked. That was fun to find because it was covered with a heat shield.
In addition, I found a vacuum hose that had a leak in it. It goes to the cruise control. I replaced the vac hose and fixed the EGR pipe leak.
Anyway, do I need to reset the timing?
The EGR should be closed at idle anyway so should it effect the timing? Since the idle and advance are controlled by the computer would the vac lead I found effect the timing / idle?
I'm 60 miles from my timing light so...
roller_steve
Mar 18, 2025 11:57 AM
RBraverman
Feb 10, 2015 08:12 PM
Schmederling
Escape & Escape Hybrid
Dec 16, 2014 09:35 PM
Motorhead1978
May 30, 2013 07:31 PM
mmjax25
1997 - 2003 F150
Apr 21, 2008 07:17 AM
