It is an 85 F150 4x4 300 4spd with granny has 3/4ton rear springs and a 2in lift.
Can yall tell me what axle ratio i have
and what transfer case and the transfer shift pattern please
axle code:H9
Trans code: A
thanks it has 104k runs awsome pulls hard
i just found 2 hi by shifting it then seeing if the front drive shaft would spin don't know where 4 hi really is it has a shift *** from a 2500 dodge
could you tell me the pattern?
this occured to me flip down the sun visor to see if if the shift pattern is there. you'll be able to tell the difference of 4hi and 4 lo. i have the 300 and grany 4 spd. 4lo in first BARELY even reads on the speedometer and the motor is screaming!
do u think it will pull my friends linclon town car on a 25ft G/N
for 10 miles to his house with ease?
it feels like it would pull a house down
What model tranny do i have ?
