cleaning pcv valve
Old Jul 17, 2004 | 07:08 PM
hster's Avatar
hster
cleaning pcv valve
I have oil coming out of my pcv valve on top of the valve cover . 1981 f150 6 cyl. Do you think I can clean the pcv valve and tube that runs to the air filter? Will this work and should I try some high mileage oil additive (engine restorer)? What brand do you recommend? I am going through about 2-3 qts per week . Low driving.
Old Jul 17, 2004 | 07:20 PM
tsc's Avatar
tsc
Try replacing the pvc valve (their dirt cheap, like 2-3 bucks) It's basically a ball bearing inside a plastic housing, that opens up when enough pressure is built up-yours could be fouled up. As to the oil consumption, I really don't know. Engine oil flush? or Seafoam? due to the crud build up? causing the oil to "squirt" out
Old Jul 17, 2004 | 07:23 PM
Torque1st's Avatar
Torque1st
Posting Legend
Replace the PCV valve rather than clean it. Just because it rattles does not mean it is good. The valves wear out and do not meter the airflow properly. The PCV should be replaced annually.
If you have PCV problems and the valve hasn't been replaced in the last 6 months replace the valve.
Old Jul 19, 2004 | 07:58 PM
bpwilliams's Avatar
bpwilliams
Ya sounds like yer gettin alot of blow-by, that can also be caused by the oil retun holes under the valve covers on either end of the head being clogged.
jdq
2009 - 2014 F150
Feb 27, 2017 08:53 AM
cbass139
Jul 26, 2012 06:07 AM
PurerockRacing
Modular V10 (6.8l)
39
Mar 16, 2006 08:53 AM
action jackson
May 12, 2005 11:42 AM
JStan
Oil & Lubrication
Oct 24, 2003 03:37 AM
