87 tach problem
Old Jul 17, 2004 | 03:41 PM
TJ86's Avatar
TJ86
87 tach problem
Hi all, I just updated from my old reliable 86 to this not so reliable 87, but I'am sure with your help we can get things sorted out.First problem --as soon a I turn on the key (before it's even running) the tach jumps to 800 rpm and just stays there. It doesn't matter how fast the engine turning it stays at 800 till you turn the key off then it drops to 0.I cleaned the sensor and the plug but it didn't make any differance. Any ideas??
Old Jul 17, 2004 | 05:14 PM
Dave Sponaugle's Avatar
Dave Sponaugle
What does it do if you unplug the sensor and turn it on?
Old Jul 18, 2004 | 05:22 AM
TJ86's Avatar
TJ86
That was a good question, it does the same thing unpluged...What does that imply a bad tach??
Old Jul 18, 2004 | 11:35 AM
Dave Sponaugle
That would be my first guess.
Old Jul 19, 2004 | 09:31 PM
thechad's Avatar
thechad
I have found that the tach's themself go bad really easy in the 6.9 and 7.3 so if you know how take it out and test it, or take it somewhere to be tested.
Old Jul 20, 2004 | 11:51 PM
Spectramac's Avatar
Spectramac
This will sound horrible, but whenever my tach acts up, I give the dash a whack and it straightens back out. Helps my sticky voltmeter too. I imagine my truck will get back at me some day by blowing all the dashlights in the middle of the night.
Old Jul 21, 2004 | 09:07 AM
lilbuj's Avatar
lilbuj
Voltage
Does anyone know the proper voltage that the tach sender should be putting out. I am getting ~.9 VAC at idle and it will go up to ~3 VAC when it the engine is reved up? Is this the correct range?
How can one test the tach?
Thanks,
Joshua
Pete Kildow
Large Truck
24
Nov 25, 2013 02:40 PM
RydForLyf
Large Truck
May 28, 2012 05:48 AM
big_pun
19
Aug 13, 2010 12:19 AM
dazzleaj
1983 - 2012 Ranger & B-Series
May 22, 2007 05:50 PM
GST97
Sep 19, 2004 12:45 AM
