1978 - 1996 Big Bronco
Gremlins inside dash!
Old Jul 17, 2004 | 08:08 AM
trailblazer's Avatar
trailblazer
Hey just found this board there is alot of good info here. looked through the archives and couldn't find anyone with my problem. I have a 93 bronco 351 and when I am driving and am giving it gas I get a buzzing sound from behind the dash on passenger side it sounds like a cross between a radio buzz and a leaf being stuck in the vent.But it is neither of those things Noise stops once I let off the gas and starts again when I get back on the throttle the more gas I give the louder it gets. noise is definately inside the cab behind dash does anyone have any ideas could it be some sort of relay that controls the throttle/fe? this is driving me insane. Thanks in advance for any help.
Old Jul 17, 2004 | 09:03 AM
genueix's Avatar
genueix
Maybe unsafe...but it wont be if you're on a good length of road. Get someone to stick their head under there as you cruise down the road and feel around with a flashlight. If you get lucky and the noise IS inside the cab...you just might find it. It might be as easy as a jittering glovebox or a shorted wire.
Old Jul 17, 2004 | 11:47 AM
kameronth's Avatar
kameronth
A bad cat can trick you into thinking it is inside the dash.
Old Jul 17, 2004 | 02:24 PM
buckinbronco'95's Avatar
buckinbronco'95
it sounds like a bad radio ground. that is usually the same type of sound a bad ground makes.
Old Jul 19, 2004 | 06:36 PM
trailblazer
you maybe on to something with the bad radio ground i did notice the door speaker on that side had some static in it I will check it out thanks to all who replied.
TallTexan
Nov 19, 2012 10:07 PM
dewking
1983 - 2012 Ranger & B-Series
Apr 23, 2009 04:01 PM
Gary E
Sep 28, 2006 07:44 PM
BigMattXXL
16
Feb 11, 2004 04:11 PM
dfawvor
Aug 1, 2003 02:10 PM
