E150 1995 speedometer bouncing, cruise control also
Old Jul 17, 2004 | 12:50 AM
flying dutchman's Avatar
flying dutchman
From: i live in a little village in the netherlands
Hello,
I joint your forum today, I live in holland in the land of the small cars, but drive a E150. because petrol is about 6 dollars a gallon, my van runs on propane. I have it now since about 8 months, and am slowly working my way through it.
I changed filter and gear oil, now it shifts fine. I changed the pignon bearings in the rear end, including the differential bearings, and that reduced 15 dB of noise, meaning it is almost perfect. But I am stuck with a very annoying problem. My speedometer is bouncing up and down. when I drive slowly, it is just moving a little, but when I go faster, it jumps 20 mls up and down. As I read in the list I am not the only one with this problem, but I did not read a sollution yet. overhere it is very difficult to get parts for testing or trying. does anybody have any suggestions??
kind regards
henk
Old Jul 17, 2004 | 09:20 PM
Jeeves's Avatar
Jeeves
bouncing spedometer
I've had that before, found either a dry(needs lubrication) or frayed cable inside cable housing from speedometer to transmission.
Old Jul 17, 2004 | 11:11 PM
flying dutchman
bouncing speedometer
the system on here is a fully electronic one, and I allready replaced the VSS in the differential housing
Old Jul 18, 2004 | 06:46 AM
Phantom's Avatar
Phantom
I would tand to think that it waould be the only mechanical part of the system, the stepper motor that drives the speedo needle.
Old Jul 19, 2004 | 04:01 PM
flying dutchman
if it would be the needle motor, how does it effect my cruise control. the van reacts to the speed shown by the speedometer, wich is no fun to drive on cruise control
henk
Old Jul 19, 2004 | 06:14 PM
Yakk's Avatar
Yakk
Pull the rear cover from the differntial and check the ring gears bolts.
If they come loose, you'll have an erratic speedometer.
At least this happened to a friend with an 1993 E-350.
If you have cruise, does it work or not?
I live in holland in the land of the small cars,...
Bicycles too?, at least thats what I was taught in "Social studies."
-J-R-
Old Jul 19, 2004 | 08:04 PM
Fordcr's Avatar
Fordcr
do a search on PSOM.....
Old Jul 19, 2004 | 10:42 PM
flying dutchman
bikes and bouncing speedometers
Hello ""yakk"
Yes, holland is also the country of the bicycles too. a lot of the travelling is done by bike, and almost all roads are equipped with seperated lanes for it. my children travel 8 mls one way to school on a bkie. Then to your tip, I already opened the rear end because of noise, and installed new bearings. the rear end now runs fine again, but the speedometer stil jumps up and down
regards, henk
orangeford
Dec 7, 2013 02:39 PM
*2fords*
May 21, 2013 08:25 PM
NielsBech
1983 - 2012 Ranger & B-Series
Sep 20, 2006 06:24 AM
Fairlane62
Nov 5, 2004 06:51 PM
Bogaski
16
Dec 12, 2001 02:00 PM
