IDing an axle
Jul 15, 2004 | 07:23 PM
IDing an axle
hey I am having some trouble IDing an axle can someone help please the tag reads
4:10 D8TA ACD
610023 6
I know the 4:10 part but I can't figure out if this is a Dana 44 or a 60 or other? Any help is appreciated. By the way this is a 78 F250 4X4. Thanks
Jul 15, 2004 | 07:28 PM
rear is probly a dana 60. i asked the same question a while back. 76 f250 4x2. dont think that makes a difference...
Jul 19, 2004 | 04:57 PM
If you can post the axle ID off of the vin tag on the driver's door, and if the axle is original, I can tell you what the axle is. On the far right side of the vin tag is a space labeled axle. Post the numbers listed under that portion of the tag. Axle #24 would be a dana 60 4:10. Axle *B4 would be a dana 60 limited slip 4:10.
Aug 9, 2004 | 12:10 PM
Aug 9, 2004 | 12:26 PM
H9 is a 3750 lb limited slip 4:11 axle ratio
Sep 15, 2004 | 05:02 PM
Sep 15, 2004 | 06:13 PM
22J ?
My doortag says 22J, tag on the axle says 4.10, 22J comes up as 3.07 ratio on codes I've looked at.
Sep 15, 2004 | 06:38 PM
You can use the VIN and data plate decoder link found in the Read First: FAQ thread at the top of this forum.
Sep 15, 2004 | 10:37 PM
Since the 4,10 axle is only on the Dana 60 & DSana 70,I would say ......
it's Dana 60
The J stands for power steering .
It has nothing to do with the axle.
The H means Limited Slip on any given ratio.
Sep 16, 2004 | 01:02 AM
The VIN and data decoder shown is for vehicles manufactured in the US. Is there a decoder for those built in Canada, such as mine?
Sep 16, 2004 | 01:14 AM
I was able to find the information in my owners manual. H5 is a limited slip with 4:10 ratio, 3800 #'s capacity..
stercorarius
Jun 19, 2013 01:50 AM
64f100swb
Oct 1, 2008 03:56 AM
MEPR
17
Jun 27, 2005 08:21 PM
youngguy
Mar 15, 2004 05:35 AM
unioncreek
Oct 31, 2002 12:54 PM
10 ,
22j ,
610023 ,
acd ,
axle ,
d8ta ,
data ,
decoder ,
ford ,
h9 ,
plate ,
truck
