axle id help?
Old Oct 1, 2008 | 12:09 AM
64f100swb's Avatar
64f100swb
axle id help?
im having trouble id'ing my axle
i have a 1964 f100 swb 2wd w/ a fe motor and c6 swap.
the data plate says "12"
the axle says
WBG-F2
3.89 4AE 301
any help would be greatly appreciated!!!
Old Oct 1, 2008 | 03:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
the axle says
WBG-F2
3.89 4AE 301
Welcome to FTE
WBG-F2 / 11 / Ford 9 inch / 8 3/4" Ring Gear / 3.89-1 / 2 Pinion Conventional-non Limited Slip / 3300 lb. Rear Axle Capacity / Large Axle Bearings / Rear Axle Parts List #91.
4AE is the date built: 5th week (E), of January (A), 1964 (4) / 301 is the code for the Ford assembly plant where the axle was assembled.
Invader6
Dec 30, 2011 09:30 PM
64f100swb
New Member Introductions
Sep 28, 2008 09:49 PM
tonydlt
May 9, 2007 07:59 PM
82F100SWB
Nov 5, 2002 08:29 PM
69SWB
Oct 15, 2002 07:22 PM
