under pressure
Old Jul 15, 2004 | 06:34 PM
geson's Avatar
geson
under pressure
hooked up pressure gauge to 302 efi 1986 van and it went 40 pounds momentarily then dropped to zero...key on not running...tried test several times always same...started van and it reads 38 lbs and holds fine..what causes the key on leakdown?
Old Jul 15, 2004 | 11:47 PM
Racerguy's Avatar
Racerguy
It sounds like you probably need a new fuel pump. The fuel pump has a check valve in it.
The supply check valve, which is normally closed, opens when the outlet pressure from the energized fuel pump exceeds the opposing check valve spring force. When the fuel pump is de-energized (i.e., engine is shut off), the supply check valve closes to maintain fuel pump prime and fuel supply tube pressure.
hsg1977
Nov 12, 2016 10:09 PM
Jason Delamarter
May 30, 2016 12:36 PM
deshet1980
16
Dec 28, 2015 03:32 AM
genscripter
13
Sep 29, 2015 07:42 PM
richrd
1997 - 2003 F150
Jun 5, 2015 05:23 PM
