351M/400 ??? which one?
Old Jul 15, 2004 | 02:04 AM
ClatonK's Avatar
ClatonK
How do I tell the difference between a 400 and a 351? Every time I open the hood on one they all look the same and have a sticker on the valve cover saying 351/400m.
Clayton
Old Jul 15, 2004 | 10:13 AM
mark a.'s Avatar
mark a.
Look where it says displacement on the sticker.
Old Jul 15, 2004 | 11:39 AM
ClatonK's Avatar
ClatonK
I have 3 of these engines avalable to me and where it says displacement on the sticker it says 351/400m.
Old Jul 15, 2004 | 09:51 PM
96-5spd302's Avatar
96-5spd302
as far as i know the only difference is the crank so i dont think it really matters which one u have
Old Jul 15, 2004 | 10:58 PM
mark a.'s Avatar
mark a.
Look closer it's on there.
Old Jul 16, 2004 | 12:51 AM
monsterbaby's Avatar
monsterbaby
your are looking at the engine family if you are seeing 351m/400 there will be another section on the sticker that will say displacement, and it will have one or the other on it without looking at one right now I think it is to the right of engine family.
Old Jul 17, 2004 | 03:15 PM
wycowboy79's Avatar
wycowboy79
My truck doesn't have the sticker on it anymore, thats the first place I looked. The VIN says it should be a 351M but the previous owner swears its a 400. I'm inclined to believe him since the carb is from an automatic tranny and I have a 4 speed. How would I tell short of pulling the oil pan?
Chris
Old Jul 18, 2004 | 03:39 AM
scroob's Avatar
scroob
"How would I tell short of pulling the oil pan?"
That's the only way. Because of the angle, you can't even use the old wooden dowel in the spark plug hole trick.
Old Jul 18, 2004 | 01:46 PM
wycowboy79's Avatar
wycowboy79
Thats what I thought. I am not near as familiar with the 351M/400 as I am with the FE engines. I've got to replace the rear main seal on this engine anyway so I'll figure it out then.
Chris
Old Jul 18, 2004 | 02:02 PM
battered_bronco's Avatar
battered_bronco
weight and string na na na it hangs..
i am thinking 8/32 and monofiliment with a glued knot
wht do you think any one got one of both for experimentation???
i read that on bubba's sight too
oops na na na on me just thought only would work parked sideways on a 30* slope(think this is a 60* engine) it will just ride the clyd wall otherwise
so it kinda might work in the right condions
Old Jul 19, 2004 | 07:04 PM
motorhead_83's Avatar
motorhead_83
Here is where it says disp. on the sticker (if you have one)
[IMG]C:\Documents and Settings\Dan Olson\Desktop\400m[/IMG]
breezesboy
May 4, 2015 05:37 PM
Bob Crain
46
Nov 14, 2012 07:00 PM
jf77
Apr 28, 2012 12:32 PM
78MeanGreenBronco
24
Nov 23, 2008 06:28 AM
mirage820
Jul 30, 2004 03:32 AM
