I will be getting a lift soon, and my local performance shop is pushing me toward the "Superlift" brand.
Can anyone give any input on their newer line of lifts- the Superride Select Series? I hear it is nice.
What can you guys tell me about it?
Skyjacker lift kits are great because they are fully customized to your specific year, make and model. They've been noted by some to be stiffer but handle and look awesome.
Actually, the Superide Select kits have been called the Cadillac of lifts, because the design of the leaf springs is supposed to make them ride softer/ smoother.
I know that they offer the thicker leaf springs that have TEN thinner leafs, instead of 3-5 thicker leafs.. This design with more, thinner leafs is supposed to make it smoother, with a little bit softer ride.
I DO appreciate your input though ToughBuiltFord... Curioius, when you say it is a bid stiffer, are you referring to the newer Superride Select line, or the older kits?
That IS the kind of input I am looking for though... Are the Superride Select kits a rougher or smoother ride?
I recommend you take a look in the thread below for opinions about lift kits. It's a sticky in the SD forum. There's nothing wrong with Superlift, but it's always best to know what else is out there, as well as their pro's and con's. A few people listed Superlift as their lift.
The Bilstein Independent compression and rebound valving is a clear plus factor for the Superride SS kit along with the ten thinner leafs which is proven to smoothen the ride from owners i've met. That lift thread has some great examples of what you can do.
I have a 4" skyjacker and a 6" superlift on two 78 3/4 tons. I like the skyjacker better. I think the skyjacker has a better ride and more flex. Always go with a lift system (all springs, no blocks). A lift kit has front springs and rear blocks. Blocks is the cheap and easy way out. Do it right the first time with springs all the way around. The only blocks that should ever be used are the ones from the factory.
So perhaps you can contribute a stiffer Skyjacker feel with a lift kit due to the rear blocks and it's smoother with all springs. Anyone done the same with Superlift for comparison?
I've seen no evidence of problems with using blocks (unstacked, 5" or less). Maybe you could elaborate on why they're wrong to use. And unfortunately stiffer and softer tend to be opinion based. That's what makes it so hard to tell someone which lift springs give a smoother ride, because opinions and optional equipment (shocks, tires, etc.), vary so much and have a profound effect. I've heard and been in many a debate about which springs give a smoother ride than another. The only agreement I think I've run across and agree with, in terms of aftermarket lift springs, are that 8 and 10 leaf progressive springs ride smoother than thicker 3 and 4 leaf lift springs. In my opinion, I've yet to ride in a truck with aftermarket lift springs, whether they're progressive Deaver's or custom "tuned" National's that ride smoother than my stock '04 with heavy-service front springs. But again, that's my opinion.
I guess I just pay real close attention on the performance of my springs. I find it easier to tell differences on the older trucks than the newer ones. I have done some real serious offroading with some guys who had some good rigs with blocks. I have seen blocks shift, slide out, crack and split apart. You don't have that problem with springs. That is one thing really tough to fix on the trail. Also, blocks use a longer u-bolt that is usually the same diameter as the shorter one used before. Which makes the bolt weaker. If a person just uses their lifted trucks as a show piece and doesn't ever take them off of the pavement, then blocks will work fine.
Experiences definitely do vary. I've been an avid off-roader for over 20 years now and have yet to see a properly set-up block kit have any problems. I've been with guy's that have axle wrapped there lift springs and guy's with blocks underneath bust apart their springs and shackle, but so far no blocks that have split or been ejected. My own experience with my dually with rear blocks has been the same. And while I may baby the engine, I'm brutal with the truck off-road. Enough to have slid the rear tires sideways into a rock at about 30 mph causing me to come to a dead stop with only "slight" damage to the wheel and no shifting of the blocks. I've also been with guys in there SD's with blocks that treat them like I do my rockcrawler and seen no problems. But don't get me wrong. I'm not advocating that a block lift is better than a spring lift. What I am saying is that I've never seen or heard of a properly set-up and built block from a major manufacturer having the problems you described.
EnviroCon, Glad to see that you have not seen any problems with blocks. I tend run across folks with bad luck I guess. I couldn't tell you who the manufacturer was for the blocks that malfunctioned. It very well may not have been a reputable manufacturer.
I'm scheduled to get 4" prologic front coil over shocks and 2" rears with the stabelizers, arms, and 6" lift. If you ever get the chance to look at the 4" front prologic coil over shocks do.
