Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
sheet metal brake.
Old Jul 13, 2004 | 12:13 PM
64ford4x4's Avatar
64ford4x4
sheet metal brake.
was wondering if anyone knew of a cheap break, or could tell me how to make one.
Old Jul 13, 2004 | 12:36 PM
sdetweil's Avatar
sdetweil
what do you mean by 'cheap'? What material are you bending, and how much of it?
for example, from Harbor Freight medium or small
Sam
Old Jul 13, 2004 | 12:45 PM
64ford4x4's Avatar
64ford4x4
tanks for the reply, by cheap i mean a couple hundred, am makeing own cab mounts out of 16 gauge steel. thanks Rod
Old Jul 13, 2004 | 03:15 PM
sdetweil's Avatar
sdetweil
sorry, another question.. Is that because you can't get existing mounts for under a 'couple hundred' or you want to do this for learning and/or you want a brake and this is a good cause?
I am doing 16ga on my 55-F100 floorboard.. but I will have someone else do the 60 inches of bending I need cause its only once..
Sam
Old Jul 13, 2004 | 07:24 PM
64ford4x4's Avatar
64ford4x4
sheet metal brake
I have found mounts, but yes I would like to try to make them myself just for the expereance, and to try and make it a little stronger, I worked in a machine shop for a few years and I was doing the sand blasting for them, we worked with stainless steel.
Old Jul 15, 2004 | 10:41 AM
sluggo36's Avatar
sluggo36
Malco makes a 48" break that sells for about $300.00 new. It's lightweight (40 lbs or so). It won't bend 16 gage, though. You would need an 8' break to bend 16 with a nice crease. I would look around for a box and pan break. It has removable fingers so you can put a 90 degree fold on all four sides of a piece of metal. A 4' box and pan break used should be around $600.00. There is usually a company that buys used sheetmetal equipment in most major cities. You could call Benoit Sheet Metal Equipment in Woodinville, WA for a reference. http://www.benoitsheetmetal.com/
Good luck!
Rob
Old Jul 15, 2004 | 11:44 AM
ranchero77's Avatar
ranchero77
when choosing the right brake you will need to consider the length of the bend with the gauge your bending. one that bends a max 22 gauge full length piece of steel could maybe bend 16 gauge steel 4" long but the machine will usually have a limit on the thickness it will accept.
but if your going to get one look for a pan/box. you can make your own tag boxes, bolt bins, catch pans, and whatever else. harbor frieght has a 12" one for about 160 bucks. it might handle 18 ga steel?
Old Jul 15, 2004 | 12:08 PM
3Mike6's Avatar
3Mike6
I bought an Import finger brake, from w w w use-enco com, total with delivery was 379.00, they had a special on shipping...anyways, it's a 4foot brake, rated at 16g mild steel and 18g SS for full length.
Also, they have a lesser expensive model (in 4 foot) rated at 18g MS and 22G SS.
They also have decent prices on smaller brakes.
If you have a Harbor freight around, or they stock inexpensive import stuff as well.
