Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Mig Welder
Old Jul 12, 2004 | 04:31 PM
C@ppy1961's Avatar
C@ppy1961
Mig Welder
Hi all,
quick question here, would a 2.4 KVA petrol generator have enough power to run a mig welder on low settings to weld say 18-20 gauge mild steel? - Thanks
Old Jul 12, 2004 | 06:22 PM
Overkill-F1's Avatar
Overkill-F1
Check the input amperage required for the welder, it may have a min/max requirement. ...Terry
Old Jul 15, 2004 | 01:44 PM
Putt's Avatar
Putt
Most 120 volt mig welders require a dedicated 20 amp service, as long as the generator is capable of that you should be good to go. You might have problems if the input voltage fluctuated at all, it would affect the output voltage, arc, amps like changing the settings.
If it is a 240 volt, then you really need to check the required amperage of the welder.
