Decent Shocks?
Old Jul 13, 2004 | 08:01 AM
Twins's Avatar
Twins
Decent Shocks?
Greetings from a newbie!!!
I have an old 1978 F150 4x4 I picked up last month that I plan to rehab. I am wondering what a good set of heavy duty shocks would be for this truck. It seems to have 4 shocks in the front and 2 in the rear...is this normal?
Also it has some sort of spreader clamp in the front coil springs...how do I tell if it has a "lift" and how much lift in order to buy shocks...?
Any help/guidance is really appreciated
Thank you
Gerard
Old Jul 13, 2004 | 08:54 AM
beartracks's Avatar
beartracks
Hi, I've had good luck with the Monroe Gas Magnum. Same as the NAPA Gas Grande I think.
Old Jul 14, 2004 | 08:17 PM
STGFordCrazy04's Avatar
STGFordCrazy04
a few weeks ago I lifted a cj5, not the same but close enough for this purpose. after lifting the truck to the desired height I placed a jack underneat the driver side of the axle and raised the jack until the driver side was at full compression or just before the tire hits the fender. I first measured the distance between the upper and lower shock mount on the driver side. This gives you the compressed length. Say for example 11" Then I went to the passenger side and measured from shock mount to shock mount and that gave me my extended length. Lets say 17" I went to my local napa and asked for shocks that have an extened length of 17" and a compressed length of 11" They punched it in their computer and found some that were alittle shorter (about a 1/2 inch) than I wanted but for 16.95 each I couldnt turn them down.
hope this helps and isnt too confusing
Old Jul 14, 2004 | 09:25 PM
LxMan1's Avatar
LxMan1
I have always liked Gabriel Gas rider LT shocks. I use them on my 77.
Old Jul 14, 2004 | 10:41 PM
beeboy's Avatar
beeboy
I just picked some up on eBay, so far so good!
Old Jul 14, 2004 | 10:57 PM
Torque1st's Avatar
Torque1st
Posting Legend
You can find more information in the suspension forum and aftermarket forum.
Old Jul 15, 2004 | 03:40 AM
Twins's Avatar
Twins
Thanks Folks!!!
You have been most helpful!
Gerard
1978ShortboxF-150
Offroad & 4x4
Aug 13, 2011 06:34 AM
pdqtimetrialer
Apr 26, 2010 07:18 PM
321poof
Aug 5, 2006 03:25 PM
fishmanndotcom
Aug 14, 2002 05:55 PM
viet667
Feb 9, 2000 10:06 AM
