high rpm's
Old Jul 11, 2004 | 08:18 PM
xltlariat87's Avatar
xltlariat87
high rpm's
hello all, on my '87 f-150 with 5.0 4spd transmission 31x10.50r15 tires,
at 65mph it's turning 3000 rpm's is this normal or not. every thing is basically
stock on the truck,the tires were changed and the exhaust was changed also.
was thinking of changing the transmission to either a 5spd or automatic.
any help on this would be appreciated.
Old Jul 11, 2004 | 09:49 PM
mrwizard's Avatar
mrwizard
Sounds about normal.
Old Jul 11, 2004 | 10:19 PM
351ballsofford's Avatar
351ballsofford
that's exactly what mine does but it's a 5.8 but at 65mph its at 3000 rpms
Old Jul 11, 2004 | 11:24 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Check your rear end gear ratio. Make sure your clutch is not slipping.
Old Jul 12, 2004 | 01:22 AM
SoCalDesertRider's Avatar
SoCalDesertRider
3000rpm at 65mph with 31" tires with a manual tranny in direct gear (no overdrive) calculates out to about a 4.30 axle ratio. That doesn't sound believeable in a 1/2 ton with 31" tires.
Your speedo is probably off because of the tire size change, so you're probably going faster than the 65mph your speedo is showing. The difference between 29" stock tires and 31" tires is about 7%, so your actual speed is probably around 70mph when your speedo is showing 65.
3000rpms at 70mph with 31" tires in direct gear calculates to about a 3.95 gear ratio. Closest available ratio would be 3.91, but that's an odd ratio to change to. Most people change to 3.73 or 4.10.
I'm thinking either your clutch is slipping alot or the tach and speedo readings you reported were incorrect 'cause the calculations don't come up with an answer that makes much sense. Were you guestimating the engine speed?
Old Jul 12, 2004 | 05:07 PM
Lumpy87's Avatar
Lumpy87
That's exactly where I was running when I had exactly the same size tires.
I think they want you to turn a higher rpm with a Windsor motor. At least with a 5.0L.
I have 33's now so it's a whole new ball game. Not sure what ratio I have now but I will be needing to change it.
TonyJestis
May 30, 2012 10:12 PM
Bulldawg1081
13
Jun 14, 2010 02:05 AM
jph37
Sep 27, 2006 08:11 PM
f15zero
May 10, 2004 08:22 AM
