thinking about a change
Old May 9, 2004 | 10:07 AM
f15zero's Avatar
f15zero
Question thinking about a change
currently have a 87 f150 with 300 i6 and 4 spd (np435) ... almost never use 1st ... 4th is ok for back roads but really could use a 5th gear for highway ...looking at trading for a 95 with 5 spd and same engine ... anyone have any comments on that engine/transmission combination ???
Old May 9, 2004 | 11:49 AM
boond0cksaint's Avatar
boond0cksaint
i have a 96 i survey land out of, 300 i6 w/ a t-5.
Old May 9, 2004 | 12:08 PM
MustangGT221's Avatar
MustangGT221
It's not a T-5, thats used in the mustangs. It's a mazda 5 spd (M5OD). That transmission doesn't have that low 1st gear like the np435 does. That's nice for towing trailers or starting out on hills because it gets you moving easier without burning the clutch so much. The M5OD is a good transmission for an F-150 that isn't being beat on. My F-150 sees 35" tires off road as well as trailers and cargo. I use it more like an F-250 or F-350. I have the M5OD and it's taken everything I've thrown at it so far, but I don't think it'll last very long. It's perfect for the everyday kinda guy who throws a load in there once in awhile, I need something stronger, which will be the ZF 5 speed out of the F-250s and F-350s.
Old May 9, 2004 | 09:14 PM
f15zero's Avatar
f15zero
not planning on doing a lot of heavy work ... the main reason for thinking about the change is have a higher (5th) gear for the highway
Old May 10, 2004 | 08:22 AM
mavinwy's Avatar
mavinwy
Or, if you like your truck the way it is. Change the rear end to a 3.08 or something. (both if 4X4). Just another option.....
Jim
Beatertruck
Oct 28, 2011 06:59 PM
hawkmaneg
Nov 21, 2007 10:11 PM
Brown89f150
May 8, 2004 04:32 PM
peterdroy66
Sep 30, 2002 11:31 PM
OSUCBY26
Nov 28, 2001 11:31 AM
