taking a cat off
Old Jul 11, 2004 | 07:18 PM
RustyWallace's Avatar
RustyWallace
taking a cat off
i have a 1989 f250 351w
its got that one big cat and its got a egr tube goin into it and i wnat my truck louder so im gunna tkae my cat off. will that mess up my computer or mess up my truck or what?
Old Jul 11, 2004 | 08:03 PM
Chris_ce's Avatar
Chris_ce
Is there a o2 sensor behind the cat?
Old Jul 11, 2004 | 08:55 PM
drewcoolness99's Avatar
drewcoolness99
there shouldn't. At least theres not one my f150. but it should just have 1 right there at the y pipe in front of the cat. It will just make the exaust smell.
Old Jul 12, 2004 | 01:04 AM
wojo1989's Avatar
wojo1989
I dont have much experience on the F-series but I do the 5.0 Stangs. The only thing that happens is that the airflow is changed and can cause the O2 sensors to read wrong. That may cause your check engine light to come on.
It will cause your exhaust to smell.
Steve
Old Jul 12, 2004 | 02:37 AM
GlennF250's Avatar
GlennF250
Rusty, can I have your old cat if you don't need it?
My truck won't pass state inspection.
Thanks
Old Jul 12, 2004 | 01:41 PM
95 F150's Avatar
95 F150
Good advice has been given above. I drove my truck without covertors for a couple of weeks and couldn't stand the way my exhaust smelled like a lawnmower so I had a high flow cat installed and am happy with it.
I would just leave it alone unless it is clogged up, if it is buy a high low cat to replace it with.
Old Jul 12, 2004 | 04:16 PM
RustyWallace
glennf250
if u pay for shipping
Old Jul 12, 2004 | 06:00 PM
wojo1989's Avatar
wojo1989
If you take your CAT off spend the little bit extra for a CATCO high flow CAT or any brand. It wont hurt your performance that much and will keep you from stinking up ever intersection you pull up to.
Steve
Old Jul 12, 2004 | 06:07 PM
kens64's Avatar
kens64
Good advice. CATCO and Magnaflow both have good high flow cats.
Old Jul 12, 2004 | 07:04 PM
bfsid's Avatar
bfsid
My cat is on, but I still have a bad sulfur fart smell to my exhaust. Is this a bad convertor, a bad O2 sensor, other? Has new fuel regulator and fuel pump 6-months ago. Check engine light comes on occasionaly.
Old Jul 12, 2004 | 07:57 PM
kens64's Avatar
kens64
bad convertor, probably the cause of the CEL too.
Old Jul 12, 2004 | 08:50 PM
wojo1989's Avatar
wojo1989
Hey Bfsid,
How many miles on the O2 sensor? If you a high miles on it I would change it. That is a culprit for the on/off Check Engine light. It will take care of that as well as give you a little better gas mileage.
matpasch
28
Jul 6, 2016 04:47 PM
Squisher
6.2L V8
Sep 2, 2015 10:00 AM
NCfisherman
Jul 5, 2014 10:49 PM
plhlt89
Aug 4, 2011 06:54 PM
03F350GUY
Oct 5, 2009 05:13 PM
