Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Bleed valve on air compressor?
Old Jul 11, 2004 | 03:58 PM
laka's Avatar
laka
I have a Campbell Hausfeld 7HP/60 Gal. compressor. On the pressure activated power switch, there is a small needle valve that is activated when the pressure is reached and the power is shut off. When power is on, the needle valve is closed. Can't imagine what the purpose of this is? Any ideas? Just looking to satisfy my curiosity.
Thanks
Old Jul 11, 2004 | 09:49 PM
Mike W's Avatar
Mike W
Some setups use that to bleed air out of the compressor output port so the motor won't have a load when it starts.
Old Jul 12, 2004 | 05:40 PM
GLR's Avatar
GLR
On my CH 7HP/60 gal it is the unloader valve as Mike W says. I've had mine since '91 and only thing I have had to do to it was change the check valve yesterday.
Old Jul 12, 2004 | 08:12 PM
laka's Avatar
laka
I assume my check valve is toast. As the bleed valve will eventually bleed down the entire tank. All I can find for check valves here are some for $20 CDN, and they dont look like exact replacements. Where abouts did you get yours?
Old Jul 12, 2004 | 10:58 PM
GLR's Avatar
GLR
try www.chpower.com (or www.campbelhausfeld.com) manual is avail plus service center near you. I think they had a min. charge so I bought 2 check valves.
jpucovsky
Jun 8, 2008 03:09 PM
rv'n_in_ga
May 21, 2008 01:30 PM
kjg26
Offroad & 4x4
Jan 17, 2007 01:11 PM
muckypaws
1978 - 1996 Big Bronco
Apr 4, 2005 07:19 PM
dagriggs
Electrical Systems/Wiring
Jan 21, 2005 08:00 PM
