2002+ 2 DR Sport Explorer Question
Old Jul 11, 2004 | 11:15 AM
dawid311's Avatar
dawid311
Is it possible to drop in a larger engine into this vechicle? And if so, what kind? 5.0 V8? How much faster do you think the Explorer will be? And also what other mods would you have to do in order to handle the extra horsepower?
Old Jul 12, 2004 | 04:39 PM
dawid311's Avatar
dawid311
Bump!
To The Top My Good Man!
Old Jul 15, 2004 | 08:14 AM
dawid311's Avatar
dawid311
Come out come out lol
Old Jul 15, 2004 | 09:17 AM
thelonerangerxlt's Avatar
thelonerangerxlt
I'll jump in since no one else has.
Everytime I climb under mine to change the oil, I think of a 5.0 swap. The motor mount holes are already there, and I think everything would be a bolt-on. You'd just about have to have a donor vehicle, though. The 8.8" rear diff is plenty strong, so that's no problem. As are the brakes. The torsion bars might have to be changed, and maybe the driveshaft, but other than that, it should be a straight forward swap.
Old Jul 15, 2004 | 09:47 AM
dawid311's Avatar
dawid311
Thanks for the reply. What about the tranny though? There is no way a stock one will hold up is there? Especially if I get a crate engine, 5.0 v8 345hp.
What kind of tranny would you recommend?
Old Jul 15, 2004 | 03:21 PM
thelonerangerxlt
None of the 4.0 transmissions will bolt up to a 5.0. Best bet would be to get a 5.0 Explorer donor, and exchange the engine and transmission as a unit, or at least use the transmission with the crate engine. You'll also need the PCM and various other electricals.
It should be quite a hot rod.....
kadrocker
17
Apr 11, 2009 02:15 PM
RoyalFord
1997 - 2003 F150
16
Nov 28, 2004 04:07 PM
sdfd504
Exhaust Systems
Sep 20, 2004 05:21 PM
1984 f-250
Ford vs The Competition
May 5, 2004 06:15 PM
