Help needed!! hub assembly questions!!
Old Jul 10, 2004 | 10:46 PM
wera racer's Avatar
wera racer
well i have a 99 ranger 4x4 vacum hubs with 4wheel ABS. i have the front end apart but i cant find the hub nut! i have the vacum assembly off the end of the axl, rotor off etc. so when i look at it i see the hub (the part with the lubs for the wheel etc) and inside of that i see the axle. nothing on the end etc. if you look down along side the axle and into the hub you see a orange plastic lock washer thing. thats it, i cant see anything else. it seems to me the whole wheel bearing hub assembly would slide right off over the axle. i have all 3 bolts out from behind etc. but i cant find the nut. any help would be appreciated. thanks!
Old Jul 11, 2004 | 10:13 AM
wera racer's Avatar
wera racer
bump....................
Old Jul 12, 2004 | 03:45 PM
wera racer's Avatar
wera racer
for future refernce, simply remove the plastic lock washer, and the 3 bolts on the knuckle and then pry the hub assebly off a bit and it will pop right off. now i just have to wait for the new one and try to put it in. i assume from the lack of reeponses to this post that most people havent done this to one of these trucks. but in case someone feels the urge, does anyone have any recommendations as far as greasing ot not greasing the axle, new hub etc. and any advice on how to make sure the vacum is still working and air tight when i am finished?
Old Jul 12, 2004 | 04:42 PM
Peter94's Avatar
Peter94
I wish I could help you out. I know if you use too much grease on the hub it will mess it up. I have manual hubs now, but before i had the auto's and they quit working
enduro4231
Jun 15, 2022 08:48 AM
rcguy79
2004 - 2008 F150
Jan 10, 2014 06:00 PM
prettygooddeerhunter
21
Jan 13, 2011 05:02 PM
gafordman1978
Mar 26, 2003 07:05 PM
