Sponsored by: Kumho
power steering foam
Old Jul 10, 2004 | 06:49 PM
loonkids's Avatar
loonkids
power steering foam
hey guys,
i just got my 78 ford f150 running, finally.... and all the brakes work now, i got the carb issues sorted out, i think. but now the power steering sucks...its so incerdibly hard to turn.... and the fluid is foamy when I get back from taking it around the block. any ideas.... its on a 351 M by the way, if that helps any.
thanks
nick.
Old Jul 10, 2004 | 07:01 PM
73highboy4x4's Avatar
73highboy4x4
either the pump is low on fluid and is cavitating or the intake hose has a leak and is sucking air into it. if you keep filling it with fluid and running it the bubbles will work out of it as long as there is not a leek in the inlet hose
Old Jul 11, 2004 | 08:29 AM
loonkids's Avatar
loonkids
ill give that a shot, thanks...
so, you dont think the pump is shot.
Old Jul 11, 2004 | 08:51 AM
73highboy4x4
did you take it off to work on your engine, if the fluid is low it will foam but if you add more fluid it will stop it from foaming. it will take a few days to get all the bubbles out. check your fluid leval after your truck has sat overnight.
Old Jul 11, 2004 | 09:27 AM
teds74ford's Avatar
teds74ford
When I had my truck apart, it did this when I put it back together. After it has set, jack up the entire front end, fill it up, and then start the engine and turn the steering lock to lock. You could probably get it out eventually, but jacking it up removes any strain on the system and makes it easier to bleed out. Ted
Powerstroke1229
Jan 9, 2013 10:35 PM
Mats Nilsson
Apr 10, 2010 09:18 AM
1976F250HiBoy
Nov 26, 2009 10:30 PM
Andy_Bracy
Jun 10, 2007 10:10 PM
jonesie925
Mar 24, 2007 09:55 PM
