V10 throttle body spacer?
Yea thats kinda what I figured, only reason I asked is because I know that on two stroke engines (250r or 350 banshee) if you space the reeds & carb it gives you way better throttle response & better mid range & its proven, but I guese thats hole different animal. I guese a TBS is kinda like a tornado, a piece of C#%*. Thanks,Doug.
I bought one off ebay. Not impressed with it, didn't see much of an improvement. In fact the 1st tankful I about died at the fuel mileage. I guess it was the computer adapting to the Throttle Body Spacer ( I GUESS ) because that 1st tank was horrible. My fuel mileage is back to 11 or 12 MPG now.
Those spacer really crack me up! As if they really created a tornado effect in only 1" with the shallow turns in the spacer. Even if it did, do you think the tornado effect would be maintained as the air travels (very quickly mind you, enough to create up to 20" vacuum!!) through 12 or more inches of intake runner that has a sand cast finish and numerous bends, down the intake side of the head, around an intake valve and being redirected by the design of the cyl head chamber??? As if that is not enough, when valves slam shut there is a reverberation air pulse that travels back up the intake. Very unlikely to see anything other than a pretty anodized turd behind your throttle body....
