Spout Connector Location
Old Jul 11, 2004 | 10:43 AM
TurboVern's Avatar
TurboVern
Question Spout Connector Location
I have a 1989 Ranger 4x2 with a 2.9L engine and 5 speed transmission. It's running rough and missing at cruise. I checked and the distributor is loose. I want to set the timing and tighten the distributor before I start checking for other problems. I can't find the Spout Connector! I've traced the harness that runs from the distributor along the passenger side of the engine but I don't find the plug! Every plug coming off that harness is connected to injectors or sensors on the engine, I can't find any extra plugs or see anything that should be connected that's not. Where the heck did they put that damn Spout? Am I overlooking something or just not looking in the corrct place? Help!!!
Old Jul 11, 2004 | 11:06 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Welcome to FTE!
Not exactly sure on yours, but on my 94 4.0 it's on the wiring harness common to the core support, between the battery and the core support itself (left side of truck).
Old Jul 11, 2004 | 12:18 PM
87 XLT's Avatar
87 XLT
On my 87 2.9 it's on passenger side laying on the valve cover right next to the PCV valve.
Old Jul 11, 2004 | 04:27 PM
Elfasto's Avatar
Elfasto
Yep, and depending on year of Ranger/ BII with the 2.9L engine it can be either the little rectangular plug or an inline plug.
Old Jul 11, 2004 | 05:34 PM
TigerDan's Avatar
TigerDan
I have an '89 4X2 with the 2.9. Here are some pictures of my spout connector above the pass. side valve cover. Yours should be the same.
https://www.ford-trucks.com/user_gal...=48306&width=2
https://www.ford-trucks.com/user_gal...=48305&width=2
https://www.ford-trucks.com/user_gal...=48304&width=2
-TD
Old Jul 11, 2004 | 07:28 PM
TurboVern's Avatar
TurboVern
Thumbs up
I finally found it, I was looking in the wrong harness. TigerDan, your pictures lead me right to it. Now all I need to do is set the timing and see if I have any other problems, good thing I bought that scanner. Thanks everyone!
Old Jul 11, 2004 | 07:49 PM
TigerDan's Avatar
TigerDan
No problem, glad I could help. -TD
Old Jan 3, 2018 | 06:17 PM
NCRRangerDanger's Avatar
NCRRangerDanger
Find replacement spout connector?
​​​​​​Where can I purchase a new spout connector? The previous owner of my truck must have lost it because they just shoved a staple in there to complete the circuit. I've tried autozone, nappa, and o'riellys but none of them have it. I believe I have the correct part number, E53Z14489C.
Old Jan 7, 2018 | 08:42 AM
ArmamentDawg's Avatar
ArmamentDawg
What is a "Spout Connector"?
Old Jan 7, 2018 | 09:27 PM
78Broncoinpieces's Avatar
78Broncoinpieces
SPark OUT its a signal the computer uses for timing. physically its a simple jumper plug between 2 wires.
since its a jumper plug anything that conducts electricity can be used to replace it.
when the plug is disconnected the computer reverts to base timing, that's when you set the timing. put the plug back in and the computer adjusts the timing as needed.
tempest411
24
Jun 5, 2025 11:11 PM
Ed89250
Electrical Systems/Wiring
Nov 23, 2017 08:22 PM
jranly
Sep 10, 2017 11:46 AM
aaronrodgers38
20
Mar 2, 2017 05:32 PM
kjs5055
Nov 10, 2016 05:51 PM
