Window Seal Removal
Old Jul 7, 2004 | 05:41 PM
Woodsman_30350's Avatar
Woodsman_30350
Window Seal Removal
I have a 50 F-1 with window rubber that is old and rock solid. Any suggestions on the best way to remove them?
Old Jul 7, 2004 | 05:55 PM
mtflat's Avatar
mtflat
Careful application of a good sharp wood chisel. Worked on mine.........
Old Jul 8, 2004 | 01:19 AM
laynrubber's Avatar
laynrubber
Use a razor blade and cut the seal from around the window, just be careful not to score the window.
Old Jul 8, 2004 | 05:39 PM
cheinz46's Avatar
cheinz46
I just had the windshield and back window weather stripping replaced in my 57. The glass shop pros cut the glass out of the rubber while the glass was still in the truck.
Old Jul 8, 2004 | 05:42 PM
Woodsman_30350
Thanks all. I guess there are a lot of ways to tackle this. My truck came from Arizona and all the rubber is like cement. Might try a combination of the chisel and Dremel to get all the seals out. I don't think I can salvage the glass anyway.
Old Jul 8, 2004 | 07:53 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
IF the glass is decent and you want to keep it. I would coat the seal with silicone and let it sit a few days it will help soften the seal. Also you can use Piano wire to cut out the window if need be.
Old Jul 8, 2004 | 11:32 PM
nixer's Avatar
nixer
try carb cleaner and not the spray type im talking the real metal bottle type and dont get it on the paint, but should turn that rubber to goo!
vermillion95xl
Jan 15, 2014 07:09 AM
mantta
Appearance & Dress-Up
Aug 16, 2008 12:09 AM
breakfastpoo
Aug 5, 2006 03:00 PM
CJK440
1997 - 2003 F150
Feb 1, 2005 04:30 PM
