boost
Old Jul 7, 2004 | 03:34 PM
HOMEYJAMES's Avatar
HOMEYJAMES
boost
How much boost is safe on these 6.0???? My Edge shuts down at 34.5, just when its starting to run good!!!!!!! Homey
Old Jul 7, 2004 | 03:41 PM
dport's Avatar
dport
The Edge stuff is limited by EGT. What is your EGT when you reach 34.5 boost?
Old Jul 7, 2004 | 05:27 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
If EGT is the case, then bump up the max egt setting on the unit. If it will not go any higher, try relocating the thermocouple for the pyrometer to the downpipe. this will lower the reading.
If you do this, it would be in your best interest to put in a secondary pre-turbo pyrometer and monitor it yourself. You dont want to get it TOO high.
Old Jul 7, 2004 | 05:47 PM
bighoss550's Avatar
bighoss550
"too much" being 1500degrees pre-turbo
Old Jul 7, 2004 | 06:49 PM
SpartanDieselTech
Former Vendor
Thanks for covering me I guess that was a rather needed peice of information i didnt include
Old Jul 7, 2004 | 08:48 PM
04F250CC60's Avatar
04F250CC60
Bighoss not to step on your toes but...did you mean to say 1,270?? 1,500 is pretty hot Pre Turbo
Old Jul 7, 2004 | 08:51 PM
SpartanDieselTech
Former Vendor
For sustained use, I would say you are correct. At the track, however, you could see 1500 or 1600 without any damage. Since it is not prolonged.
Old Jul 8, 2004 | 01:08 PM
user 708242442's Avatar
user 708242442
1500 is alot even if it is a second or two.You are doing damage at that temp.
Old Jul 8, 2004 | 05:47 PM
bighoss550's Avatar
bighoss550
its just hot! i build tractors to pull at 1450-1500deg w/ the stock bottom end
w/ceramic, we get a 2200deg gauge and try to run around 2000-2100deg
a stock diesel can stand 1500deg for a few seconds, and ive seen many stock cummins push the needle to 1700-1800 for the length of a pull, and drive home. they do it over and over and it used to scare me too, but it seems to be ok with an airesearch, but schwitzer's are more sensitive. all i use are airesearch(garrett) and thats whats on my '03
1500 is def the limit for a stock diesel tho...if u go for long times at 1500 u may get problems
1300 is a good street limit for towing ang such
Old Jul 8, 2004 | 05:50 PM
bighoss550's Avatar
bighoss550
my toes need a little stampin from time to time i see 1250 on a long hill w/ a load in my 550
1270 really isnt much if ur at the track, but its plenty on the 8% grade for 10miles...
Old Jul 8, 2004 | 06:10 PM
04F250CC60's Avatar
04F250CC60
I understand. Sure for a second or two those temps aren't that scary. I come from an construction equiptment diesel background. If say a track type backhoe is just steady throwning dirt at WOT (2200 rpm) and I happen to point my infra red thermometer at the turbo's turbine section and it reads 1250+ and I dont tell the operator of the condition and he continues, I know I'll be replacing the turbo shortly thereafter. I've pulled them off and have seen no turbine blades left. And the operator wonders where all the power went!
Old Jul 8, 2004 | 06:44 PM
bighoss550's Avatar
bighoss550
ya constant heat is bad...mr. mackey...mmmmkkkay..
sorry... u are right, i was just talkin in short or semi-short term
what kinda turbos do those things have???
64ponton
Dec 5, 2007 08:47 PM
Chance_Thomas
Apr 24, 2007 03:10 PM
mcbryant
May 15, 2003 05:49 PM
mcneal
Feb 15, 2001 06:50 PM
