changing plugs
Old Jul 6, 2004 | 01:20 PM
belliebuc's Avatar
belliebuc
Unhappy changing plugs
I found a nice 87 ford , only has 70k on it. started changin a few hoses,and doin some maint. on it,went 2 change the plugs(im sure they r origanal) and noticed corrosion so i sprayed them down with penetrating oil.now be4 i pull them out would it be better do do this with a warm engine or a cold engine.think i read somewhere that the 300 had aluminum heads so i figure i got 1 shot. man i would hate 2 pull the treads out. am i 2 parinoid or is there steps 2 take. plz any help would be greatly appreceated.
buc
Old Jul 6, 2004 | 01:44 PM
couleeman's Avatar
couleeman
I never have had a problem (replaced plugs twice). I did them cold, I didn't want to burn my hands.
Old Jul 6, 2004 | 01:55 PM
belliebuc's Avatar
belliebuc
well i once pulled some treads out of a brand new honda so im allittle parinoid. my wife says 2 put the big wrenchs away and buy some smaller ones,mabe shes right
Old Jul 6, 2004 | 02:13 PM
63redtudor's Avatar
63redtudor
I've never heard of a stock 300 aluminum head, if you've got one then you've probably got the only one! To my knowledge there's only one & its for racing only (no water passages). Just pull the plugs out, don't think that you can hurt that motor.
Edwin
Old Jul 6, 2004 | 10:44 PM
mattri's Avatar
mattri
Edwin's right, the 300 has an iron head. Just take the old plugs out and when you put the new plugs in start them by hand so you know they aren't cross-threading.
Old Jul 7, 2004 | 12:20 AM
MontanaFord's Avatar
MontanaFord
just get yourself about a 4-6" extension and use whatever size plug socket (i think you need a 13/16") and run them in by hand till you can't get them any farther, and tighten them down with the rachet...that's how i've always done mine...and i've always done them cold, so i wouldn't burn my hands...really hate workin on a hot engine....lol...easy stuff to do...good luck...
MontanaFord
Old Jul 7, 2004 | 09:55 AM
quicklook2's Avatar
quicklook2
YOU MUST DO THEM COLD! read any manual and it says this. even though no aluminum heads i use that silver thread stuff on the threads.
Old Jul 7, 2004 | 02:29 PM
belliebuc's Avatar
belliebuc
ya i can c it now, thanks every1.
i guess the easiest things can sure look the most confusing.
Old Jul 9, 2004 | 08:25 AM
Beast12's Avatar
Beast12
Do what he said. Or kind of said...... Put anti-seize on the new threads. This will make it easier (and you less nervous) next time you do it. Good luck!
-Matt
Old Jul 10, 2004 | 11:16 AM
quicklook2's Avatar
quicklook2
-Matt
just goes to show you: drinking and surfing forums does not mix!
sad that a canadian has to translate my posts. hahahaha!
i could not remember that anti-seize was what i used.
Old Jul 10, 2004 | 11:59 AM
Beast12's Avatar
Beast12
it's ok....I got yer back!
-Matt
Old Jul 10, 2004 | 04:17 PM
whimsey's Avatar
whimsey
I had a 1989 with the 300 engine. while I changed the plugs at 30,000 miles the first time and around 60,000 miles the second time I still had difficulty gettting a couple of them out. I didn't use antisieze till I reinstalled new plugs at 60,000 miles. For removing the tough ones I was advised to work the spark plug wrench back and forth. It worked and loosened the plugs that would not budge by just trying to loosen them in the "normal" fashion. Spraying them with the penetrating oil will help also. And yes the head is cast iron. That engine is nearly indestructible.
Whimsey
Old Jul 10, 2004 | 08:48 PM
Phrogman46's Avatar
Phrogman46
It allways helps me to use a rubber hose to start the plugs that way you cant cross thread them. And you were working on a HONDA before, not a Ford.
kas83
Modular V10 (6.8l)
Feb 25, 2014 07:49 PM
NDNMOJOMAN
2004 - 2008 F150
Sep 7, 2010 01:45 AM
BigPigDaddy
Jun 8, 2010 02:58 PM
breathment
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 21, 2004 09:35 PM
LOTR-HAMMER
15
Jun 18, 2004 06:10 PM
