Modular V10 (6.8l)
Any issues with a time sert?
Old Feb 24, 2014 | 08:36 PM
kas83's Avatar
kas83
I've been dealing with a random misfire, and think I tracked it down. When I changed all the plugs and coils, I noticed that cylinder #4 had a time sert in it. I was able to torque all the plugs at that time, and keep them tight. I was checking coils and boots tonight, and noticed #4 and #5 boots melted to the plugs. After ripping the boots off, I checked the plugs. When I pulled them, they loosened up pretty easy, but threaded out fully. Each plug looked good, including the threads. Upon reinstallation, they would not torque down fully. They won't pull, or blow, out, will only thread back out, but will not tighten up.
Where do I go from here? I put 2 new boots on and ran it back home. Seems just like before checking everything, random misfire but otherwise good.
Old Feb 24, 2014 | 08:48 PM
Wolfboro's Avatar
Wolfboro
Just curious , how did you determine that the inserts were Timesert and were not a different brand inserts (like , Helicoil,etc.).
Old Feb 24, 2014 | 09:09 PM
kas83's Avatar
kas83
The chamfered top edge of the insert and diameter. Was a solid insert unlike wire of a helicoil. Asked at Napa what the insert looked like, top was definitely the same style as what was in the head.
Old Feb 24, 2014 | 09:44 PM
Wolfboro's Avatar
Wolfboro
This is the first time I am hearing about a timesert failure .
You may want to go timesert .com for more info . You can also call them see what they will recommend .
Good luck,
Old Feb 25, 2014 | 07:49 PM
kas83's Avatar
kas83
I received an email reply from them. They said that the standard time sert should work on #5, and that the night sert should correct #4. Without any knowledge of who did the first one, or how long ago, we can only speculate that it wasn't done properly.
I've had the truck 2.5 years now, bought it with the repair already in place. Since this side head gasket seeps oil, and I plan on fixing that, the plug repair will probably wait until then.
cyclone-429
1997 - 2003 F150
Sep 17, 2014 08:19 AM
tater_51
Modular V8 (4.6L, 5.4L)
Aug 15, 2013 05:42 PM
dr1
Jul 6, 2012 11:19 PM
nflfreak43
May 28, 2009 09:17 PM
Buzzard616
Modular V10 (6.8l)
May 18, 2009 07:28 PM
