Sponsored by: Real Truck
2004 KR SD Keyless code AGAIN!!!
Old Sep 30, 2007 | 09:59 AM
ilo9's Avatar
ilo9
Question 2004 KR SD Keyless code AGAIN!!!
Pulled radio nothing there!! Right kick plate nothing there, behind fuse panel nothing there... I cant find the darn thing anywhere. This is starting to drive me nuts... Any help out there??
Old Sep 30, 2007 | 10:56 AM
fordboy2's Avatar
fordboy2
I have beeen told the only way to find out is to have the dealer read it with the scanner.
Old Sep 30, 2007 | 09:52 PM
conger's Avatar
conger
Mine was up behind the radio, facing down. The only way to read it was with an inspection mirror and a flash light from the floor facing up. I had to remove the lower center panel and cup holder. It was a real challenge. 5 digits, but the numbers are big and easy to read. If you've got an 04 that's where it will be.
Old Oct 2, 2007 | 05:20 PM
cool*ray's Avatar
cool*ray
I was able to find mine without using a mirror, but the module was hidden away behind the white polyester-looking insulation. The module was roughly 4x6, black, upside down, and appeared to have 3 wiring bundles connected to it. You'll know it if you see it...
Old Oct 2, 2007 | 07:06 PM
flyinnuts's Avatar
flyinnuts
On my 04 CC 6.0 its exactly where the previous posts indicate. I had to remove the fuse panel cover, with a good flashlight and a dislocated shoulder i did find the box. i didnt need the mirror however. mine was upside down as well. good luck.
ladystroker
1997 - 2003 F150
Oct 27, 2012 11:26 PM
F-350PSD
27
Jul 16, 2011 02:33 PM
jtybt
Jul 30, 2010 09:24 PM
03PSDX
Testing.....
Sep 30, 2007 12:48 AM
spears
Car/truck Buying Advice
Jun 3, 2005 04:29 PM
