Check Engine Light On, Code Scanner not Functioning
Old Sep 4, 2002 | 07:43 PM
atikovi's Avatar
atikovi
I just got a 2001 Explorer with over 60,000 miles and CEL is on. When I hooked up a code scanner to the Data Link Connector it wouldn't turn on. The DLC fuse #5 is fine. Pin #16 on the DLC is supposed to be (as far as I was told) 12 volt power for the scan tool but it has NO power. Is there a open circuit somewhere? Can I just put a jumper wire to it to get the scan tool to work?
Old Sep 6, 2002 | 04:56 AM
marragtop's Avatar
marragtop
I believe there is a way to jumper a wire and pull the codes from the CEL on the dash. Suggest searching the forum for 'pull scan codes'.
Old Sep 8, 2002 | 01:46 PM
otter95X's Avatar
otter95X
Old Sep 9, 2002 | 11:21 AM
reberhardt's Avatar
reberhardt
Not since the '95 Explorer.
miker67
Mar 28, 2016 08:26 AM
Dutter 2
Jan 30, 2016 09:42 PM
joegeds
Aug 10, 2015 11:39 AM
hooptytank
Jul 27, 2015 10:26 AM
Rusty_S
General Automotive Discussion
Jun 24, 2012 10:30 AM
