Different kingpin sizes?
Old Jul 5, 2004 | 09:05 AM
6t6merc's Avatar
6t6merc
My '74 needs kingpins, so I plan to remove the complete axle assemblies and replace them with a rebuilt pair. The replacements are from a '78 (I think). I got a kingpin kit and found that the 7/8" pins in the kit are much too small. It seems they should be at least 1". I know that kingpin size won't matter once the beams are assembled, but now I'm concerned that the kingpin size is not the only difference. Can I be sure that the replacement beams will bolt in place of the originals and that the '74 bearings and brake parts will fit?
Eric
Old Jul 6, 2004 | 01:22 AM
oldhalftons's Avatar
oldhalftons
they changed the kingpins in 75
65-74 (65-72 are drum spindles)use one size and 75-79 use another size.
the I beams need the right spindles
73-74 disk spindles fit 65-74 beams, 75-79 spindles fit 75-79 beams
the beam/spindle/radius arm assembly as a whole will bolt into any 2wd truck from 65-79
All F100/F150 spindles from 73-79 use the same brakes and bearings.
All F250 spindles from 73-79 use the same brakes and bearings.
Marklea
Apr 13, 2016 02:14 AM
f100today
Apr 2, 2016 08:09 PM
FuzzFace2
Feb 6, 2016 09:28 AM
joefordtruckf250
Aug 3, 2014 06:36 AM
TheFixer
Sep 15, 2009 06:18 PM
