45-60mph Vibration
Old Jun 21, 2005 | 04:30 PM
  #31
Big T's Avatar
Big T
Originally Posted by Blue Blooded
??huh?!?!
Yah, that's what I said.................
Old Jul 30, 2005 | 03:45 PM
  #32
Blue Blooded's Avatar
Blue Blooded
What kind of vibration are you guys talking about? I get a little bit of "nibble" in the steering wheel at about 50-60mph. Anything over or under is OK.
Well, had it re-aligned and tires rotated at a local shop. Smooth sailing now.
Old Aug 1, 2005 | 01:17 PM
  #33
alol24's Avatar
alol24
My '04 f150 lariat is doing the same thing! I have had the tires/wheels checked/rebalanced 3 times and now I have learned that Ford is apparently having some sort of suspension problems with the 04's. Let me know what the solution may be if you happen to find out, thanks!
Old Aug 2, 2005 | 11:57 AM
  #34
JBD's Avatar
JBD
I have experienced pretty much everything described above in my 04 supercrew with the 5.4. They have rotated tires, replaced two tires, the drive shaft, installed the dampening device (which forced me to remove my aftermarket tow hitch), and most recently some steering mechanism for the nibbling.
I am sorry to say after these 6 trips to the dealer I am still experiencing, although significantly less, mild vibrations at 50mph and nibbling at 70mph. In addtion all four tires are showing premature wear. I am concerened to say the least. The problem is not near as bad, but I think it should be perfect. This is my fourth ford, but the first ever new car I have purchased.
I have heard that the Continental Tires are to be blamed for a lot of the problems. My next step I think is to force them to change all four tires to BFGs.
Old Aug 2, 2005 | 04:56 PM
  #35
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome JBD, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 4, 2005 | 12:29 PM
  #36
chessdotcom's Avatar
chessdotcom
Brand new 05 F150 is doing the same thing. Not even a week old. Starts at 65mph and worst at 70-71. Having them look at it today.
Old Aug 4, 2005 | 09:46 PM
  #37
porschebreath's Avatar
porschebreath
My 04 was fine till I had 20 rims and tires put on it. I recieved them from discount tire direct. The truck had a vibration 60 - 65 . I had a road force balancing done and they said all the tires are out of round. Discount tire sent me new tires and I sent the old ones back. I had the new tires put on and re- balanced and it is worse than ever. I don't know what to do. I did notice that they stuck the wheel weights on the INSIDE rim on the inside edge instead of tgetting closest to the outside of the rim. I can't even drive the truck. One of the rims came up with a minor dent durring the road force. I'm waiting another week and I guess another road force at $30 a tire. Do I take it to the dealer? , will they say , Your problem , aftermarket rims. What do I do?. Thanks and sorry about the rant. Totally frustrated.
Old Aug 5, 2005 | 08:52 AM
  #38
derek4343's Avatar
derek4343
hey toypuller,can dealers do this road force balance.i've never heard of it.
Old Aug 5, 2005 | 02:40 PM
  #39
chessdotcom
Just got off the phone. They did the same test on mine. Two tires failed the road force test. They replaced them. Picking up the truck later today. I'll let you know what I find.... (if it worked or not)
Yes the dealer can do the test.
Old Aug 11, 2005 | 03:08 PM
  #40
chessdotcom
two tires did the trick.....
now to the a/c
Jeff396
Jul 22, 2012 09:20 PM
expo54bx
Oct 2, 2010 12:52 PM
mjs
Jun 21, 2005 09:46 AM
Bart99GT
1983 - 2012 Ranger & B-Series
Jul 22, 2004 03:34 PM
fd167
1997 - 2003 F150
15
Aug 25, 2002 03:10 PM
