shock/steering arm interference
Old Jul 4, 2004 | 01:16 AM
nikwave's Avatar
nikwave
on the driver side the shock and the sterring arm are pretty close ,but when there is suspension travel it hits,the shock is already with the body upwards and there is a dent on it from when it was mounted with the body downwards.is there any aftermarket arm or any trick to fix this?
Old Jul 4, 2004 | 05:38 PM
Fritolay's Avatar
Fritolay
i have a half ton but on mine the shock is mounted behind the axle and the steering arm is in front of it.
Old Jul 5, 2004 | 01:30 AM
nikwave's Avatar
nikwave
yes on mine the shock is behind too but is barely 1 1/2" from the shock rod.
Old Jul 9, 2004 | 12:18 AM
460EFIhighboy's Avatar
460EFIhighboy
Look to see if the "stop bolts" are intact. Most likely they are not.
Old Jul 9, 2004 | 07:42 PM
nikwave's Avatar
nikwave
yes they are intact,i guess i could unscrew it more to gain clearence,but will loose some turning radius.
Old Jul 17, 2004 | 05:05 PM
nikwave's Avatar
nikwave
i think i solve the problem i took the upper shock mount from its original location an move it 2" to the right where the motor mounts are and screw it there,the distance between holes is the same.
Tyler S
43
Feb 25, 2014 03:05 PM
ಠ_ಠ
May 7, 2013 07:22 PM
Ryno22980
Jun 30, 2010 09:19 PM
soooop
Feb 19, 2010 07:54 AM
tony b
Jan 3, 2007 08:07 PM
