Trailer Tail Lights
Old Jul 3, 2004 | 06:07 PM
barebackjake's Avatar
barebackjake
Exclamation Trailer Tail Lights
my right side brake and turn wasnt near as bright as the left side, but now i dont have anything. im not getting it at the plug at the back or the relays under the hood? also it has the 7way rv plug on it and im not getting reverse lights?? anybody have a wiring diagram on this. dont want to just start changin parts. all fuses good, relays cycle when power is applied wiring going back is good. left side brake and turn works, and all running lights including ones on right side. truck lights work fine also?????
Old Jul 3, 2004 | 06:28 PM
wlihntr's Avatar
wlihntr
email me and i will send it to you
Old Jul 3, 2004 | 06:37 PM
johnsdiesel's Avatar
johnsdiesel
HERE is a wiring diagram for the 7-pin plug. Maybe someone else has the diagram for the wiring under the hood.
Old Jul 3, 2004 | 10:34 PM
barebackjake
thanks for the replys guys. this is off topic but do you have a reccomendation for a service manual for this, i have a haynes and it worthless. and the ford shop books are $900
Old Jul 3, 2004 | 10:57 PM
wlihntr's Avatar
wlihntr
check your email it should be there...hope you get it figured out
Old Jul 3, 2004 | 11:11 PM
barebackjake
wlihntr,
thanks soo much that whats i needed to get this taken care of. killed both birds with one stone, thanks again
jake
Old Jul 3, 2004 | 11:19 PM
wlihntr's Avatar
wlihntr
glad i could help...have a good trip
Old Jul 3, 2004 | 11:22 PM
barebackjake
what are thoose other two relays to that are right next to the main fuse/relay box? ive got three relays accounted for jsut trying to figure out what theese other two are the trailer harness goes into thees two??
thanks again for the help
Old Jul 3, 2004 | 11:49 PM
wlihntr's Avatar
wlihntr
those would be the "trailer tow backup lamp relay" and the "trailer tow battery charge relay". if they are not in there you need to put them in. they are a standard 12 volt relay, you can get them at most auto parts stores, when you buy them they will have a plastic tab on them with a hole in it to mount. cut off that tab flush with the top of the relay so it will fit under the relay cover
Old Jul 3, 2004 | 11:52 PM
wlihntr's Avatar
wlihntr
i just emailed you a pict of where all the tralier tow fuses and relays go
Old Jul 4, 2004 | 11:16 AM
Sonrio_Grande's Avatar
Sonrio_Grande
wlihntr:
I'm having major problems with mine also.
I don't have email priviledges yet so would you please email the diagram and pics to me at gboswell@sbcglobal.net ?
Old Jul 4, 2004 | 11:21 AM
Sonrio_Grande
Woops. That is pure nutcase. Let me try it this way.
gboswell (little "at' sign) sbcglobal (dot) net
Old Jul 4, 2004 | 12:06 PM
wlihntr's Avatar
wlihntr
they are on there way. and 250SD i sent you copies as well
one warning; the files are pretty big(1500 + kb each and there is 2)so they may take a while to download.
Old Jul 4, 2004 | 12:12 PM
wlihntr's Avatar
wlihntr
yours got kicked back "adress unknow"
i just tried it again, i think i may have messed up your adress the first time
Old Jul 4, 2004 | 07:59 PM
Sonrio_Grande
Thumbs up
Thank you!
1960 Ford F100
15
May 11, 2024 08:07 AM
fordtrkpuller
Mar 15, 2021 06:35 PM
salf100
Aug 2, 2010 02:31 PM
AmeriKen
1997 - 2003 F150
Jun 26, 2003 04:05 PM
slick78
Mar 17, 2002 07:06 PM
