1997 E-150 30-45 mph vibrations
Old Aug 10, 2004 | 07:29 AM
hrs999's Avatar
hrs999
I just picked up my van last night from AAMCO, they wanted to put in a new tranny, I told them to do the flush, problem is completely gone now, good as new.
Thanks
Old Aug 11, 2004 | 08:07 AM
Dennis460's Avatar
Dennis460
Talking
I wouldn't let my overdrive go in at that low of speed, your just asking to burn it up.
Old Aug 11, 2004 | 09:08 AM
pfogle's Avatar
pfogle
The overdrive SHOULD engage between 40 and 45 mph, anything lower and you'll hurt your engine and trans.
Old Aug 17, 2004 | 07:50 AM
jtesb's Avatar
jtesb
I have the same problem with my '97 F-150. Would you go with the complete flush or would a standard filter/fluid (where just the pan is dropped) change with the lube guard added do the trick. Truck has about 74Kmi. Don't know if trans. has ever been service, just bought it about 8k miles ago. Thanks.
Old Aug 17, 2004 | 08:20 AM
dbizek's Avatar
dbizek
Don't chance it. Get a complete clean and flush by Ford unless you know someone at AAmco. They are con artists and want to sell everyone a new trans. Ford $159.00, alot cheaper than a new torque converter. Don't wait to long. My 97 was better when I picked it up but it took about 100 miles for it to completly stop the shutter.
Old Aug 17, 2004 | 08:48 AM
jtesb's Avatar
jtesb
Thanks for the reply. I'm assuming I should have the Lubeguard added also.
Old Aug 17, 2004 | 03:38 PM
dbizek's Avatar
dbizek
It was my understanding that Lubeguard was not necessary. I don't belive they put it in my van. They did replace the fluid with Micron 5. I think that has the reqired additives it needs. Ask the service tech. when you take it in.
Old Aug 20, 2004 | 07:50 AM
jtesb's Avatar
jtesb
Had Ford dealer flush trans yesterday. Seemed to take care of problem (knock on wood). Thank goodness. They said the lube guard was included in the flush kit they use. Thanks for the replies.
Philip Michaels
3.8 & 4.2L V6
May 22, 2016 10:01 PM
seattle64
1978 - 1996 Big Bronco
13
Oct 2, 2015 10:36 PM
allhuntalltime
34
Mar 29, 2013 05:07 PM
pukey
Jan 5, 2011 11:21 PM
jjoel
General Automotive Discussion
Aug 15, 2004 02:58 PM
