Aerostar Ford Aerostar
Vibrating noise from Rear
Old Jul 2, 2004 | 11:12 PM
Timothyap5vm's Avatar
Timothyap5vm
When I am driving the van, and I let off the throttle, the van makes a low clunk and then there is a pulsating noise from the rear end. The noise stops when the van is accelerated.
Any ideas?
1997 Aerostar E-4WD 4.0 liter engine.
Blue, extended, with power everything.
Old Jul 2, 2004 | 11:31 PM
90XLT_Silver_Bullet's Avatar
90XLT_Silver_Bullet
a friend of mine just went through this, if the is the same problem.
what happened was, a bearing went in the differential which caused the crown gear (which is a spiral shaped gear the turns the gaer that turns the axle shafts). remove the cover on your diff and see if there are any shavings or anything like that in the gear oil or in the housing.
what my friend did was took off the flange type thing the driveshaft connects to, and took out the assembly in the differential and removed the crown gear and replaced all the bearings and spacers and all the stuff inside there.
this may not be the same problem but its like a $700 job if you take it to the shop and have them do it, just beacuse of the labour involved.
but the bearing and spacer cost all of under $100 total so you save same mega dollars doing it yourself, and its not all the hard, just make sure there is no play in the crown gear.
Old Jul 3, 2004 | 12:16 AM
Racerguy's Avatar
Racerguy
I would also remove the rear driveshaft and closely check the u-joints to see if you have one that's seized or just worn out.
Old Jul 3, 2004 | 08:59 PM
shel 67's Avatar
shel 67
I would deffinitely second Racerguy's opinion! My van did the exact same thing last week. But thanx to some advice from the guys on FTE I checked out the u-joints before venturing into any large project. All I did was soak the rear and front u-joints with penatrating oil and took the van for a drive. About a quarter of a mile away the vibrating almost completely stopped. The rear u-joint had been seized. The following day I had both replaced. Now the van is smooth again. Good luck.
Keny1
Dec 25, 2021 05:13 PM
trike1946
Dec 18, 2014 05:15 PM
302VAN
Jun 27, 2008 07:52 AM
Brian1477
3.8 & 4.2L V6
Aug 22, 2006 04:09 PM
printerguy
Aerostar
Oct 10, 2005 07:46 PM
