I replaced my clutch switch about a year ago because I had to press the pedal almost through the floor for it to start. It was fine for awhile but its causing problems again if not worse than before.
Does anyone know of an adjustment for the switch? Or had the same type of problem. I don't know how long my foot is going to be able to hold up.
The little white retainer clip seems to be the reason my switch/pushrod keeps coming off its post. I want to "Jump it" using a part for an automatic trans truck and be done with it. I will let you know how it turns out.
