Clutch/Starter Sensor ?
Old Jun 17, 2004 | 06:12 PM
oldcoupe42's Avatar
oldcoupe42
Question Clutch/Starter Sensor ?
I have a 95 F150 with an I-6 standard shifter and recently I have had to really stomp the clutch pedal multiple times to get the starter to engage. Is there a sensor that could be malfuntioning ?
Thanks, Chet
Old Jun 17, 2004 | 06:22 PM
believer45's Avatar
believer45
The clutch has a master cylinder with a pushrod to the right of the throttle. The clutch pedal position switch (yes, that is what Ford calls it) is wrapped around the pushrod near the firewall where it goes into the clutch master cylinder. You may be able to "adjust" it a bit - further away from the firewall will make it trip sooner so you will not have to push the pedal as far.
Dave / Believer45
Old Jun 18, 2004 | 07:36 AM
oldcoupe42's Avatar
oldcoupe42
Thanks for the help Dave. I assume that the clutch master cylinder and the The clutch pedal position switch you talked about are under the hood and not in the cab near the pedals ? Again just making sure and thanks for your advise.
Chet
Old Jun 18, 2004 | 08:09 AM
wtroger's Avatar
wtroger
The clutch switch is under the dash the master cylinder is out side in the engine compartment.
Old Jun 18, 2004 | 11:34 AM
believer45's Avatar
believer45
Chet
As posted already, the master cylinder is on the engine side of the firewall, there is a pedal box inside the cab under the dash that the brake and clutch pedals attach to (and maybe the throttle for a gas engine) which is where the parts you need to work with are. Inside the cab, tucked up behind the steering column, the pushrod for the clutch and the clutch pedal position switch are between the steering column and the center transmission hump.
Dave / Believer45
Old Jun 18, 2004 | 03:49 PM
FordPerf300's Avatar
FordPerf300
I've had the same problem, when i replaced my clutch master it came with a new pushrod and haven't had any trouble yet.
Old Jun 18, 2004 | 09:38 PM
wtroger's Avatar
wtroger
I got the jumper cap of an automatic transmission truck and did away with the switch.it just depends on how comfortable you are with not having that switch.
Old Jun 19, 2004 | 05:17 PM
oldcoupe42's Avatar
oldcoupe42
Im very comfortable with doing away with that switch. Whats the best source to find a "jumper cap" from the auto trans model ? (Parts store) (Junk yard, where do I pull it from on the wrecked vehicle) ?
Thanks, Chet
Old Jun 19, 2004 | 05:25 PM
oldcoupe42's Avatar
oldcoupe42
Wooooo Hoooooooo !!! Problem fixed ! The Pushron came partly of its mounting post so I just pushed it back on and all is well again. I feel like a real mechanic now ! You guys are all great, but Im still considering bypassing that switch. Thanks again
Chet
Old Jun 20, 2004 | 11:06 AM
Len-Dogg's Avatar
Len-Dogg
shorting clutch switch
Does anybody know what color wires you have to short together to bypass the clutch switch? I looked under there last night expecting to just see two wires, but I saw 6 or 8 or something like that going into a connector where the clutch pushrod is.
Thanks,
Jason
Old Jun 20, 2004 | 09:58 PM
wtroger's Avatar
wtroger
I bought my cap from Ford. Any truck 87 or later will have one if it is Automatic. I wouldn't go shorting wires because there is 6 wires in that plug and if memory serves some go to the ecm.
Old Jul 3, 2004 | 02:53 PM
oldcoupe42's Avatar
oldcoupe42
Thanks wtroger, I just figured out that my problem is that the white plastic retainer clip that holds the pedal position swithch onto the pushrod post is cracked and allows the switch to work its way of the post and occasionally leaves me with no clutch ! Anyone know where I can find a replacement "clip" of something I can use to hold that pushrod/swithch in place (on the post) ?
Thanks, Chet
Old Jul 4, 2004 | 04:33 PM
firstonraceday's Avatar
firstonraceday
I'm assuming you're referring to the circular clip that retains the master cylinder pushrod on the steel shaft from the pedal.
The clip can still be purchased from the Ford dealer. I went through this recently, replaced the clip and shortly thereafter (like 1 hour) the new clip cracked and ended up replacing the master cylinder. So far so good. However, it made me appreciate the mechanical linkage in my 77. I've never been a fan of hydraulic clutches anyway.
Approximate cost of the clip was $8.00 and the master cylinder was $103.00.
Old Jul 4, 2004 | 04:40 PM
oldcoupe42's Avatar
oldcoupe42
Thanks for the info Jason, If I may ask, why did you replace the master cylinder ? Was it because the pushrod on the steel shaft kept falling off (even after clip was replaced) or was the M/C just worn out ?
Chet
Old Jul 4, 2004 | 04:51 PM
firstonraceday
When the new clip broke, it managed to damage the plastic end of the pushrod so that further new clips would not adequately retain the pushrod in place. The pushrod itself can't be replaced, at least not that I could see based on its attachment to the master cylinder. And I also thought that perhaps the pushrod problems could have been caused by some binding within the cylinder. So I bit the bullet and replaced the cylinder. Don't know if that was the case or not, but like I said, so far so good.
