Oil weight question
Old Jul 2, 2004 | 03:09 PM
sstclair00's Avatar
sstclair00
Oil weight question
5w or 10w??? What is everyone's opinion?
I have used both....
But recently I have noticed some rattling when I press the accelerator after releasing it for several seconds...any idea the cause of this?
Also...are all expy's power steering noisy? Fluid level is fine....just noisy?
Thanks
Old Jul 2, 2004 | 11:05 PM
FTE Herman's Avatar
FTE Herman
Your problem 'sounds' like pinging (spark knock). Probably nothing to do with lubrication. I always use the recommended 5w. Depending on your year its either 5w20 or 5w30.
Old Jul 3, 2004 | 04:14 AM
Big Craig's Avatar
Big Craig
5W20, never heard of that one before???
Old Jul 3, 2004 | 12:13 PM
tyger25's Avatar
tyger25
It says to use 5w in the owner's manual.
Old Jul 3, 2004 | 01:19 PM
High_Horse's Avatar
High_Horse
Oil viscosities very per region, in Central Fla, I prefer a 0w. Reason being it stays warm here all the time, no need for multiversions. In summer up north a 5w is nice then to a 10w in winter.
5w 20 has been around mostly in crossbread oils (syntech and such). Most of the newer Ford motors are using this, as a matter of fact I believe Ford invented it. With bearing tolerances getting tighter, a thinner oil was needed to slick up these areas.
As for the power steering noise sstclair00, what year is your vehicle? If the fluid is exceptionally dirty it can cause some noise. When does it make the noise, .....turning, just sitting, all the time?
Old Jul 3, 2004 | 02:02 PM
Matt03Expy's Avatar
Matt03Expy
Found on: AutoEducation.com
Oils meeting the SAE's low temperature requirements have a "W" after the viscosity rating (example: 10W), and oils that meet the high ratings have no letter (example SAE 30). An oil is rated for viscosity by heating it to a specified temperature, and then allowing it to flow out of a specifically sized hole. Its viscosity rating is determined by the length of time it takes to flow out of the hole. If it flows quickly, it gets a low rating. If it flows slowly, it gets a high rating.
Engines need oil that is thin enough for cold starts, and thick enough when the engine is hot. Since oil gets thinner when heated, and thicker when cooled, most of us use what are called multi-grade, or multi-viscosity oils. These oils meet SAE specifications for the low temperature requirements of a light oil and the high temperature requirements of a heavy oil. You will hear them referred to as multi-viscosity, all-season and all-weather oils. An example is a 10W-30 which is commonly found in stores. When choosing oil, always follow the manufacturer's recommendation.
Old Jul 4, 2004 | 08:40 PM
Monsta's Avatar
Monsta
Sit. Stay.
Shouldn't that be the other way around?
Old Jul 5, 2004 | 09:06 AM
buzzard's Avatar
buzzard
I've run both and noticed no difference, but I'm in Houston....there's not much need for a super thin winter oil down here. In fact I've read many technical articles that specifically say the additives used to lower the W viscosity are actually very bad for the engine.
Yes, the power steering pumps are inherently noisy. Some say flushing and refilling will help. Others even recommend using synthetic for even more noise reduction.
Old Jul 5, 2004 | 09:49 AM
High_Horse's Avatar
High_Horse
So right Monsta, this Florida sun seems to have caused confusion on my whittle mind.. ....especially after contracting up north all freezing winter....maybe I need a lighter weight blood to stop the restriction...lol.
Old Jul 5, 2004 | 02:49 PM
tsdrallyer's Avatar
tsdrallyer
I recommend staying with the 5w the way your manual indicates, because it flows well under all temp. conditions, lubes and pumps faster after a cold startup and increases gas mileage over a heavier weight oil.
Old Jul 6, 2004 | 06:53 PM
WillieWildcat's Avatar
WillieWildcat
I second this. 5W-30 is recommended so stick with it. Engine protection and fuel economy will not be compromised if you stay with it.
crabbydale
Modular V10 (6.8l)
Feb 7, 2011 01:07 AM
1973-Big Blue
Jun 5, 2010 09:57 PM
bageera
2009 - 2014 F150
Jan 28, 2010 11:26 AM
Irv
Oct 23, 2006 09:27 PM
tlinetrader
Aug 7, 2003 07:40 AM
