Overheating While Towing
Old Jul 2, 2004 | 12:56 AM
wauseon6.0psd's Avatar
wauseon6.0psd
Cool Overheating While Towing
i have a predator on my 6.0, the motor overheated twice pulling heavy up a steep grade in towing mode. in factory tune or factory hp tune the motor does not overheat. both times it overheated, the egt gauge was at 950 post turbo. the motor got hot enough to turn on the check gauges light and blew antifreeze out the cap. i called diablo sport, they said they were aware of the problem and they were going to have an update available in a couple of weeks for the problem. i wonder if water injection would help??
Old Jul 2, 2004 | 01:10 AM
blackhat620's Avatar
blackhat620
Wow now thats hot!
With 950F post turbo egt you could be seeing 1250-1450F at the pre-turbo side. I would suggest two things. Ease up on the throttle climbing the hills. I wouldn't want to see post egt above 750-800F personally (IMHO) since post turbo readings can be 300-500F below pre-turbo. Second i would have your turbo checked for heat damage.
Welcome to FTE Lots of good info and people around here
Old Jul 2, 2004 | 05:47 AM
SBV45's Avatar
SBV45
How heavy a load you pulling?
Old Jul 2, 2004 | 07:42 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
How steep of grade were you on?
How long was the pull
Old Jul 2, 2004 | 08:01 AM
bighoss550's Avatar
bighoss550
what mode did u have it in??? the 40hp? is that what u mean by "towing mode"? or u talkin 'bout tow/haul??
water injection would bring that EGT down about 200 deg or more, and it will make more power. look through the methanol/water injection thread.
Old Jul 3, 2004 | 02:44 PM
wauseon6.0psd
i had it in the 40hp mode, pulling about 13000# through the hills in PA. my post turbo egt was 950, is that too high??
Old Jul 3, 2004 | 03:29 PM
IB Tim's Avatar
IB Tim
OK who has the conversion from pre to post EGT temps
Old Jul 3, 2004 | 07:21 PM
blackhat620
Originally Posted by blackhat620
...With 950F post turbo egt you could be seeing 1250-1450F at the pre-turbo side... I wouldn't want to see post egt above 750-800F personally (IMHO) since post turbo readings can be 300-500F below pre-turbo....
Tim,
Look up a few posts
BTW it is not a constant conversion. The temperature difference between Pre & Post Turbo is not linear. Many factors (ie.. outside air temp, RPM's, boost, Load, amount of fuel) all effect the temperature change from pre to post turbo.
Old Jul 3, 2004 | 08:05 PM
IB Tim's Avatar
IB Tim
Tim,
Look up a few posts
And the placement of the thermocouple...where it actually is
Old Jul 4, 2004 | 11:34 AM
Bill Jordan's Avatar
Bill Jordan
When I bought the predator and read the instructions it said to consider grades. I took that to mean take it easy going up hills when towing a lot of weight.13000#'s is a lot of weight.
Old Jul 4, 2004 | 05:12 PM
wauseon6.0psd
i would think egt would be too high to make coolant temp overheat
Old Jul 4, 2004 | 05:28 PM
bighoss550's Avatar
bighoss550
if that # is what u are seeing constantly, its too high
Old Jul 4, 2004 | 05:46 PM
Delta's Avatar
Delta
Now you know why Ford doesn't honor the warranty when you use aftermarket parts!
Old Jul 5, 2004 | 10:49 AM
wauseon6.0psd
950 egt was the highest, it normally reads about 700/750
Old Jul 5, 2004 | 11:48 AM
bighoss550's Avatar
bighoss550
when u are towing, dont let the post reading get over 850 constant. just let up a bit... trust me... u cant afford one of these tuba's!!!!!
