Safe cylinder wall thickness?
Old Jul 1, 2004 | 09:12 PM
scottie2hottie's Avatar
scottie2hottie
Question Safe cylinder wall thickness?
What is the minimum wall thickness an engine can be bored to safely?
Thanks
Scott
Old Jul 1, 2004 | 10:03 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Bore out until you hit water, that's the max! No just foolin. Been told if the engine is for street use, no funny gas or blower you can go down to .110" wall thickness. I'd want the maximum wall thickness for strength, ring control and cooling. Beware of core shift, some blocks are way off. If your going for inches go with a bigger standard bore block and add a stroker crank. Have the block sonic checked and maped. Good boring.
I took a AMC 401 out 3/8" and installed 8 liners and a 5/8" stroke crank for a "must have" displacement engine, big muny $$$$$. Carl........o&o>.................................. ..
usuallybowtie
Oct 20, 2015 10:35 AM
atomicjoe23
Oct 10, 2008 01:02 AM
46yblock
16
Dec 21, 2004 09:10 AM
L-N-OR
Jul 7, 2004 09:28 AM
Fordman7780
Oct 10, 2002 10:57 PM
